Which woofers will replace BD5806 woofers from (MW5806) speakers?
jtomasino
I have a pair of MW5806 speakers. I need replacements woofers but Polk tells me the woofers BD5806 are no longer made and they can't cross reference the specs to tell me which woofers I can replace them with. Does anyone know which model woofers I can buy that will fit and have similar specs to the BD5806?
Answers
Let me see if I can find some information, I probably won't know anything until Monday.
Ok... thx.
Freeman Stills, Polk's transducer prototyping technician, is going to check in his files for data on that driver tomorrow.
Ok... again thx.
Thx for the info. So is there another model speaker that would replace this woofer and fit in the enclosure from Polk?
If it were me I would send that data to: https://www.madisoundspeakerstore.com/woofers/ and ask if they have a replacement that's close to these specifications.
ok... I can do that.
I've asked Polk if there is a current driver that's close.
ok...
Unfortunately there aren't any replacements or substitutions that can be used from Polk. The best solution would be either finding them on the used market or contacting Madisound.
ok... thx for checking into this for me.
