Pairing Monitor 5 with Sony TA-70 Integrated Amp
I've been going a bit crazy on Marketplace lately and have just acquired a beautiful pair of early Monitor 5s, a perfect match to the Monitor 7s which have pride of place in the living room. The 5s will become the center of a kitchen/dining room setup (a fairly small room).
I've also grabbed a few early Sony clock radios and am falling hard for the polished teak and chrome look! A TA-70 (with matching tuner) come up locally and I'm tempted to get it to drive the 5s.
My concern is that it will be under powered and overall will not do justice to these speakers. I can't find consistent specs for the TA-70 but it's either 8w or 30w per side. I know there are cheaper and better matches out there but I love the looks of these late 60s Sony products.
    xschop Posts: 5,408
    Give it a try. I'd say if the volume knob can't do the job at half-way, then look elsewhere.
    I liked the vintage look too.
  • Some googling led me to this article (which coincidentally features a picture of the Sony amp I'm considering).
    https://www.psaudio.com/blogs/copper/how-much-power-do-i-need
    Too small of a power amp can clip the amplifier and fry your tweeter
    https://sound-au.com/tweeters.htm
    This article seems to say that distortion from the amp is behind what causes tweeter damage, whether over or under powered. The distortion specs I can find on that Sony aren't great (2% or 5%).
    I'm also looking at a Sansui 1000x which might be a safer option (and less expensive).
    F1nut Posts: 51,997
    Studying the topology of the TA70 I would say it's 8wpc @ 8ohms. As long as you don't expect rock concert volume levels it will drive your speakers without issue.
    While the 2% THD rating is high by today's standards I seriously doubt you'll notice it, especially since you will be using the set up in a small kitchen/dining room area.
    You are confusing THD with clipping distortion. Clipping is the result of over driving the amp (volume turned up too high) and has nothing to do with the total harmonic distortion rating.
    IMO, for that vintage consumer grade gear the Pioneer stuff sounds better.
  • Thanks for the input F1Nut, and for the clarification of THD vs clipping distortion.
    I'll take your advice and consider Pioneer receivers, there are several good candidates available locally.
    F1nut Posts: 51,997
    edited April 2023
    Receivers are one thing, an integrated amp and matching tuner are something different.
    You should be aware that any gear that old will need service unless it has already been done.
  • I think this might do the trick.
    xschop Posts: 5,408
    edited April 2023
    Looks like something mhardy dragged home. Should pair up better power-wise.
