Coaxial Antenna --
VR3
VR3 Posts: 28,791
edited June 2004 in Electronics
Hey,
My NAD 917 preamp has the ability to be a tuner, but needs a Coaxial tuner to do it (the cable style (like time warner)) --
Anyways, do you think I could use a cable like time warner uses for the tuner cable?
If thats confusing...sorry lol
Post edited by VR3 on
  • steveinaz
    steveinaz Posts: 19,538
    edited June 2004
    What is it, RG6?
    VR3 Posts: 28,791
    edited June 2004
    Not sure --
    But it uses the same type of connection for the antenna that is on the back of a vcr...if that helps any...
  • racer4551
    racer4551 Posts: 373
    edited June 2004
    It's probably the same connection my rotel 940ax had for the antenna hook up,it used a piece of rg59 coax with an adapter to connect to the tuner and the other end went to the radio shack antenna which had a standard coax terminal.
    *HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
