Monitor 11 tweeter discussion
This discussion was created from comments split from: The Tale Of 5 Tweeters - SDA Tweeter Replacement Guide.
Testing
Testing
Testing
    heiney9 Posts: 25,492
    edited March 2023
    You only replaced one tweeter? You say they sound great? The two tweeters are different and I would think in a near field environment you would hear a difference noticeable enough to comment on. Replace the other tweeter as well so you are running the same driver.
    Just because they are "compatible" doesn't mean they sound exactly the same. One is a peerless one is the current RD0 replacement.
    Full disclosure, I've never run a pair of early Polks with mismatched tweeters (never would think to do so) so I can't say for sure they sound different, but one would think based on the 40+ years they span they do. Plus my OCD would kick in and I'd have to have 2 identical drivers.
    P.s. There is no SL2000 in any of your photos.
    P.s.s You state you upgraded tweeters (plural) photos only show (1) tweeter replaced.
    I pulled them out and installed one in one side and took pictures of the two not mounted.
    Your post is very confusing, so I went back and re-read the above line. This line now makes me think you DID replace both, but switched them up for a photo. If so, disregard the above post. B)
    Toolfan66 Posts: 18,149
    Shouldn’t the picture with the Obama button be taken down as well? Just saying..
    xschop Posts: 5,332
    At least, put him on the left channel.
  • Gardenstater
    Gardenstater Posts: 4,799
    What happened to the No Brainer sticker??
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
