Are Bluesound Powernode enough to drive Polk R600 or Polk R700?
I have also looked at Bluesound Node and Cambridge AXR100. Any doubts about this combination?
Best Answer
    txcoastal1 Posts: 13,513
    Answer ✓
    Thanx for setup suggestion.
    Did you really mean Bluesound Powernode and Cambridge AXR100?
    Not the Bluesound Node (N130)?
    My apologies over copied and pasted
    Bluesound Powernode (use subwoofer out to SB2000)
Answers
  • jbreezy5
    jbreezy5 Posts: 1,141
    Either combination should drive the speakers, but over time you will likely want to upgrade your amplification to wring out what those speakers are capable of.
    In that case, would start with the AXR100/Node combo, then if the upgrade bug bites, you will be able to sell the Cambridge more easily and for better $$$ than a Powernode.
    I did a smaller but similar setup with Sonos years ago
    This is how I would set it up
    Polk R600
    SVS SB2000 subwoofer
    Bluesound Powernode (use subwoofer out to SB2000) and Cambridge AXR100
  • Thanx for setup suggestion.
