How much does it cost for a replacement pinnacle ring tweeter?
Somebody sent me a speaker with a damaged one and I'm trying to negotiate the price difference.
Answers
Call Polk Customer Service to obtain the price.Political Correctness'.........defined
President of Club Polk -
Depending on the situation I would say 150 to 0.
Calling Polk Cs should give you the price.
@treitz3 do you have any further advice- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I emailed them on Friday, but no response.
Scan-Speak makes a ring radiator with a similar looking silver phase plug design at around $160 to $350 a pop that may look like the Polk tweeter, but I don't think they're necessarily the same as the Polk model.
https://www.madisoundspeakerstore.com/ring-radiator-tweeters/scanspeak-revelator-r2904/7000-05-tweeter-black-face-silver-plug/
I'm guessing at least $125 to buy a new replacement but only customer service would have a current price.
The design of this model with a grille would help prevent damage...
https://www.madisoundspeakerstore.com/ring-radiator-tweeters/scanspeak-illuminator-r3004/6020-10-1-tweeter-soft-dome-ring-radiator/ -
They finally emailed me back! The cost was $93 for black and $96 for white.
