Noise sources
sucks2beme
So I started using my headphones more. Had an issue where my ASL tube amp
was making noise. Both a higher hum level and random static sounds. The original
Mg-head amps always had a little hum. So I tried a bunch of stuff. In the end, I moved
the Team Mobile 5g internet to the master bedroom. I have a hard connections to my
master bedroom, man cave, and to the living room. Had the TV on a hard connection,
So all good, tv was patched back on a hard connection. Noise is under control.
So long term I'll most likely dissect the amp and try some things to help reduce noise.
The routing of wiring and grounding/wire sheilding are sub-par. Newer versions
are supposed to be better.
The 5g cylinder is not near a window, and it's father away from the side facing the tower.
Speed test seems to be just the same as before. That was my biggest worry.
