Marantz SA 8005 SACD/CD player complete
The insanity continues so I am selling my Marantz SA 8005 SACD/CD player. The 8005 has many great online reviews and is a highly respected player. It also has inputs so you can use the excellent Cirrus Logic DAC.. This unit is in excellent condition and works exactly as it should. The Marantz has a warm inviting musical sound. Built like a tank and comes with manual, remote control, and cords. Will be double boxed. Asking $675 Thanks
stereo playback for SACDs, CDs, CD-Rs & CD-RWs, and MP3 & WMA CDs
front-panel USB input (type A) for USB flash drive, iPod®, or iPhone®
rear-panel asynchronous USB input (type B) for audio playback of stored computer or streaming music files, including high-res files up to 24-bit/192 kHz PCM and 2.8 & 5.6 MHz DSD (Windows® and Mac compatible)
Windows PCs require free driver download from Marantz website prior to computer audio playback
coaxial and optical digital inputs for using player in digital-to-analog conversion (DAC) mode
high-performance 192kHz/24-bit Cirrus Logic CS4398 digital-to-analog converter and low-jitter dual system clock
USB ground/signal isolator technology to virtually eliminate PC noise
exclusive Marantz disc mechanism resists vibration for improved sound
double-layered bottom plate for vibration resistance
high-current toroidal transformer with separate rectifier stages for the analog and digital sections to prevent mutual interference
Marantz HDAM® (Hyper Dynamic Amplifier Module)-SA2 used in analog circuitry for faster signal transfer and better transient response
detachable power cable
remote control
optical and coaxial digital outputs for CD playback
gold-plated RCA stereo analog output with selectable fixed or variable output level
full-size headphone jack with volume control
remote control input/output (for use with Marantz receivers and amps with a compatible
remote control in/out jack)
