Warm sounding pre amp suggestions
I'm possibly looking to add to my pre amp collection. I currently have a Schiit Audio Freya S solid state & Consonance Ref 50 tube pre & I swap them in & out when the mood strikes me. Both pre's sound fantastic paired with the Parasound A21+ & Maggie LRS speakers. Just kicking the idea around.
Budget $1,500.
    pitdogg2 Posts: 27,877
    Parasound out of the question?
    heiney9 Posts: 25,672
    Warmer than tubes?
  • SIHAB
    SIHAB Posts: 5,807
  • Joey_V
    Joey_V Posts: 8,603
    Cary 98 though a little above the budget
    msg Posts: 10,634
    edited March 2023
    You just looking for another toy to play with, or do you feel like there's something more to gain, somehow?
    Missing anything specific? Synergy? Or just not getting your sack blown back?
    Ever tried anything Musical Fidelity? I was constantly feeling like something wasn't right until I tried a Musical Fidelity integrated, the A5. Maybe one of their pres will suit.
  • pearsall001
    pearsall001 Posts: 5,392
    Pretty much just looking for a new toy to add to my preamp collection. My current SS & tube preamps really convey the music to my liking. Different presentations and both really hit the mark on all accounts. Just curious to what else is out there to throw into the mix. I would most likely rotate the 3 for awhile then whittle it done to just 2 & sell one off. Just looking to have some fun! I came across some really good reviews & opinions on the CJ line, in particular the CJ PV14L. There's a lot of options for sure.
    mhardy6647 Posts: 35,550
    I almost bought an Adcom tuner/preamp for $100 at NEVEE yesterday -- fortunately, I thought to myself "why?" and that provided sufficient restraint. :)
  • pearsall001
    I would have passed on that one too. 🤠
  • SIHAB
    SIHAB Posts: 5,807
    edited March 2023
    There is an open box Lab12 pre1 Stereo Tube Preamplifier @ TMR that I
    have been eyeing... a bit over the budget
    https://tmraudio.com/components/preamplifiers/lab12-pre1-stereo-tube-preamplifier-black-open-box/
    I guess this would be a sideways move. :)
  • Emlyn
    Emlyn Posts: 4,901
    I'd second or third the recommendation on giving a Parasound P6 an audition. Lots of useful features.
  • engie490
    engie490 Posts: 447
    I've had 3 CJ preamps: PV14L, PV8, and PF2. IMO, the PV8 is the best of the bunch.
    The A21+ has 29db of gain though, so you might have too much gain (PV8 line stage gain is 31db).
    PF2 has 21db of gain. The PF-R is basically the same circuit with a remote.
    The Audio Research LS3 was supposed to be very good for the money, though probably not as warm as the PV8. Echo Audio has a used one with remote for $975.
    Now I see that the A21+ has gain controls on the back...go for a PV8.
    KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
  • pearsall001
    Thanks for all of your recommendations guys! I'll definitely check out the CJ PV8.
    I some some good pricing on the PS Audio GainCell DAC, any thoughts on that particular item. I have no experience with PS Audio gear.
    audioluvr Posts: 6,065
    edited March 2023
  • jmwest1
    jmwest1 Posts: 23
    I have a SGC DAC, and it sounds great. However, It's been back to them for repair once with a main logic board issue, and it's packed to go back again for a dead left channel. It might just be mine, but I'd watch out for QC issues. Also, if you have a Vizio tv the remote codes overlap.
    PS Audio Stellar Gain Cell DAC/Preamp
    Denon DVD 2910
    Quad 12L Active Monitors
    Marin Logan Dynamo 700W
  • dromunds
    dromunds Posts: 10,173
    Pearsall001: I have a PS Audio Stellar Gain Cell DAC I may sell. PM me.
    msg Posts: 10,634
    Those B&K Sonata pieces with the offboard/outboard? power supplies are neat. I have the non-pro version, the MC-101.
  • DaveHo
    DaveHo Posts: 3,584
    edited March 2023
    I currently have a PS Audio SGC, previously had a Parasound P5. The DAC in the SGC is superior. Analog was mostly a sideways move. Parasound makes it easier to incorporate a sub if you want to use line level for that.
    Incidentally I had issues with both units. Both manufacturers repaired at no cost to me other than shipping the units to them, even though I was not the original owner. However, Richard Schram is no longer at the helm of Parasound. Don't know if there are any ramifications from that.
  • pearsall001
    dromunds wrote: »
    Thanks for the offer. I want to hold off on the PS gear & others for now. I'm concentrating my search in the CJ line. Might take awhile, it seems like they don't come up for sale too often especially in my budget range.
  • engie490
    engie490 Posts: 447
    A little over your budget...
    https://www.canuckaudiomart.com/details/649631807-conrad-johnson-premier-2-tube-preamp/
    But, he's been trying to sell that piece for over a year...
    Maybe fly a different direction Phil when looking for warmth. A redone vintage console amp/pre from the likes of Scott, Eico, Magnavox, Motorola. They have that vintage warmth that older ears seem to gravitate to.
  • pearsall001
    tonyb wrote: »
    Oh so now you're saying I'm old. LOL! I self describe as "well seasoned" 🙂 I hear ya about vintage audio gear being on the warmer side. To be honest I would be leary due to their age. I'm still kicking things around & keeping my options open.
  • invalid
    invalid Posts: 1,559
    https://www.space-tech-lab.com/
    Give this guy a call, he answers his phone during business hours, and has over 50 models of preamps.
    tonyb wrote: »
    You mean like that OLD Crusty Iron Skillet over in the corner ? ............YEP!
  • pearsall001
    invalid wrote: »
    Thanks for the info. I'll check it out.
  • pearsall001
    tonyb wrote: »
    YEP...rust & all! I thought 85 was the new 40??? 😂😂
