Polk Monitor 7 speakers with two different crossovers
Hello all,
I have a question about a pair of Monitor 7 speakers I recently picked up at Goodwill. When I purchased them they had frozen woofers (MW6502) and SL-2000 tweeters. I replaced the woofers with ones from a pair of Monitor 4 (also MW6502s) that I had lying around. I replaced the tweeters with RD0194-1 replacements from Midwest Speaker. When I hooked them up the bass does not sound right. Its very boomy and overpowering. I checked the crossovers and each speaker has a different one. Pictures are attached.
Are either one of these correct for my speakers? If not, what should I look for as replacements? Or could I recap them with correct caps? And...Could this be why the speakers are not sounding right?
Thanks for any help you can give!
    pitdogg2 Posts: 27,348
    What is the difference? What is it that has you concerned that they are different?
  • bcwsrt
    bcwsrt Posts: 2,520
    Definitely hard to tell from the two different angles.
    Brian
  • Gardenstater
    Gardenstater Posts: 4,804
    I only see one crossover from two different angles. That is a Monitor 7 Series II crossover and the RD0194 is the wrong tweeter, as was the SL2000. That one should have a SL2500 or the RD0198 which is the upgrade.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • KB12
    KB12 Posts: 6
    There are two images, one of each crossover. The first one has 27 MFD caps and the other has caps that are 8 uf.
  • Gardenstater
    The Monitor 7 Series II has 27uF electrolytic shunt capacitor on the MW low pass circuit, and 8uF electrolytic (parallel with 2.7 Ohm resistor) and 12uF mylar (yellow) in series with tweeter.
    It looks like it could be that the crossovers are the same configurations but from different angles. You need to take better photos so we can see all the values :)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • bcwsrt
    bcwsrt Posts: 2,520
    I see “8”s all over the side of that bottom cap in the first pic, just like the one in front in the second one. You’re likely to have different values in the different positions. Better pics would help.
    Brian
  • KB12
    KB12 Posts: 6
    Here are some better pictures:
  • Gardenstater
    edited March 2023
    That's beyond bizarre because 5jr+ only had 1 capacitor (in series with tweeter). It didn't have 3 capacitors.
    Your one speaker may have been hacked and someone put the large inductor for the 5jr+ in there with the rest of the crossover for the M7 Series II. That's a new one!
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • KB12
    KB12 Posts: 6
    Ok it looks like the specs are the same for both. So these are the correct crossovers for monitor 7 series 2s?
    F1nut Posts: 52,011
    edited March 2023
    The inductor in the last photo is the wrong one for the Monitor 7. It is, as the label states, for the Monitor 5jr+.
  • KB12
    KB12 Posts: 6
    Both crossovers have a cap that is 8uf and one that is 27 MFD.
  • bcwsrt
    bcwsrt Posts: 2,520
    5jr+ MW inductor on the one with correct 7 crossovers on both then.
    So, the 5jr+ inductor would be the one sounding "boomy" or vice versa?
    Brian
  • Gardenstater
    edited March 2023
    So maybe you could send your one hacked crossover large inductor cup to @westmassguy if he has time and he could wind you a new inductor or simply add on to it to get the correct inductance. Need to go from 0.56mH to 1.75mH. It might be doable especially since it appears they used 18awg for both. Wouldn't be a bad idea to send him both and he can match them up to a tight tolerance.
    And you will need to get RD0198 tweeters
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • KB12
    KB12 Posts: 6
    Thanks for all the replies and suggestions!
  • wispolkboy
    wispolkboy Posts: 150
    could it be that polk accidentally put the wrong sticker on it? Not sure how to test the inductors, but wouldn't that be the first step?
    M7's 1982 Peerless tweeters
    M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
    M4's X2 both with Peerless tweeters
    M5Jr with SL1500 (in the garage, they sound great)
    M4.6 series2 X2 with upgraded tweeters
    SDA 2 with upgraded tweeters
