T50 system Crossover frequency point
Hi. as title, above something that isnt printed in the user manual like other other manufacturers is the crossover frequency, so would be nice to know. Many thanks Howard.
Best Answer
Answers
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,398
    edited January 2023
    Hi Howard,
    Are you wanting to know the crossover frequency between the mid range component and the tweeter? Or, the recommended crossover frequency between the speaker and an external subwoofer?
  • Aitch
    Aitch Posts: 4
    Hi SF. It's the bass/tweeter xo I require. Cheers
    mhardy6647 Posts: 35,562
    edited January 2023
    It's probably worth adding that ASR ("Amir") was actually quite impressed with the value per dollar of the T50 when they (he) tested it.
    Polk's products have generally fared quite well under ASR's scrutiny (whether you care for their methodology or not).
    https://www.audiosciencereview.com/forum/index.php?threads/polk-t50-review-floor-standing-speaker.24890/
    Clipdat Posts: 13,105
    Amir kicked my dog!
  • Aitch
    Aitch Posts: 4
    Thanks nice to know as Polk don't publish it.
  • SeleniumFalcon
    You're welcome, enjoy your Polk's.
  • Aitch
    Aitch Posts: 4
    They are lovely speakers, so musical - which is rare given the price point. definitely keepers :)
  • VSAT88
    VSAT88 Posts: 1,390
    edited May 13
    I just picked up a set of these. Tightened all the screws. There are a lot of them. 23 per speaker if you do the bottom four and the binding post post as well. These should not sound this good for the 100.00 I gave for them. Of course I am running a modded Jolida 502 with G.L. KT 88's and a decent Topping D70 DAC so no trouble "up stream" always helps. I almost want to break them open and look over the crossovers. But, I would spend more time and money rebuilding those than both are worth. I decided to EQ them some as Amir recommended and that worked great. And yes, I know this post is ancient... 2023 is the last post in this thread looks like. But, with money the way it is right now I would imagine folks would like to know that they are a good deal if you want a set of very inexpensive set of floor standers that weigh nearly nothing. 35 lbs. each. As has been often true in the past. Polk Audio comes through for the average gal/guy.
