Popping noise
subman32
subman32 Posts: 27
Ok I have a seperate amp running my high's in the front. The amp is an optimus 100W, yeah definately not the best. But whenever I crank up the volume the front left speaker makes a loud popping noise. Could this be a ground problem?? Thats the only thing I can think of. Thanks
Post edited by subman32 on
    F1nut Posts: 52,166
    edited June 2004
    It's not a ground problem, that would be a humming noise. Try swapping the left and right speakers to see if the problem follows the speaker. If it does then you have a problem with a bad driver, if it doesn't then you have a problem with the amp.
  • subman32
    subman32 Posts: 27
    edited June 2004
    I just might have to try that. I'll let ya know how it goes. Thanks
    Garry
  • subman32
    subman32 Posts: 27
    edited June 2004
    Well all I did was run the front speakers directly off the Head Unit. No popping noise or anything, thanks for the reply.
    Garry
    F1nut Posts: 52,166
    edited June 2004
    Garry,
    You are welcome. So, is it time for a new amp?
    Jesse
  • subman32
    subman32 Posts: 27
    edited June 2004
    Oh yeah big time, not sure yet what i'm going to do. It's 2:30 in the morning and I just got done installing an amp in my friends prelude. Took me an hour to figure out how I was going to get through the frickin fire wall on that thing. I tell ya, imports have so many electronics it makes me want to cry. But at least its done, I might post pics soon. I'll let ya know.
    Garry
