Help with replacing binding posts (banana plugs)
Unpacking after a move, I noticed one of my binding posts broke off. It looks like removal/replacement is not an easy thing (unless I'm missing something). I had previously done a cross-over rebuild, and I'm not looking to dis-assemble that mount again (or a lot of down-time). What's the best way to proceed with a repair (my wires are terminated with banana plugs--but I'm open to just soldering the bare wire on to that one terminal)?
(2) Polk RC80i (Top Middle)
Polk CS300 center channel
    pitdogg2 Posts: 27,447
    edited January 2023
    Post a picture of the binding post. Many of us have removed the original and would offer up an original we still have in the stash. I've done this a tiem or two. Some are splined round others hexagon and smooth. If it doesn't matter will then you have more options :smile:
  • StantonZ
    StantonZ Posts: 453
    Here's a pic (negative terminal):
    It's not obvious how you remove it...unless it's as simple as "unscrewing it" from the back (in which case I can see where a OEM replacement would work).
  • joebass3
    joebass3 Posts: 311
    It's a fairly straightforward job but does require removing the crossover. I just upgraded the binding posts on my 7b's and saved the originals. Message me your address and I'd be happy to send you one.
    F1nut Posts: 52,061
    As mentioned, you will have to remove the crossover from the binding post plate. Then you will find there are gobs of a glue material covering the binding post nuts. Apply denatured alcohol with a Q-tip or other applicator and soak the glue. After 5 minutes or more you will be able to peel the glue right off. After you've changed the post you have to reseal all that was before. Use hot glue for that.
  • StantonZ
    StantonZ Posts: 453
    Looks like I'll have an OEM replacement part soon thanks to @joebass3...so I consider this thread closed/answered! Thanks for the labor tips...and thanks to the forum.
