lsim 705 fried crossover what kind of upgrades should I do.
I notice that one of my 705's was sounding a little off and crackly. after some investigation. I found the crossover has some burnt components. my question is i have this apart and it needs replaced. I need help on what upgrade I need to do. Polk want 200 for a new crossover. that's the easy fix. but if I can improve the crossover then that's the way I want to go. TIA
Answers
    pitdogg2 Posts: 27,486
    Looks like you had them at 11 for an extended period. Appears the resistor got rocket hot and may have emoliated the cap as well.
    Clipdat Posts: 13,100
    Must've been a hell of a NYE party!
    VR3 Posts: 29,609
    whatever you decide dont mount the resistor next to the cap...
    I thought Polk would have learned with the LSi... :-p
    mhardy6647 Posts: 35,341
    edited January 2023
    Incidents like this just remind us of where all that power it takes to run modern loudspeakers goes :) Not to sound, but to heat. Yay. :#
    OK enough grumpy old man...
    On topic. it's kosher ;) to mount the power resistor offset from the board. Probably a good idea. Heat is the enemy.
    The other option is, of course, power resistors like this -- but, again, give 'em a little room to breathe.
    Many of these (like this Dale) are designed to be mounted on a heatsink.
    Outboard XOs aren't a bad idea, either. Let 'em respire!
    B)
    edited January 2023
    As a not-entirely-unrelated aside: I had a cathode bypass cap pop in my single-ended 2A3 amp due to its proximity to the cathode resistor. When I replaced the cap(s), I separated them from those power resistors.
