Streamer/DAC/Preamp Suggestions
ambiophonics
I'm looking at replacing my Peachtree iDAC that I've been happy with for years with something newer that has volume control and built in streaming. Wondering what folks are using and any experiences or suggestions.
Needs to have at least a couple toslink and coaxial inputs, volume control, and ideally stream Qobuz from a hardwired connection and integrate with Control4 by IP or RS232. New or used with a budget up to $1500.
The rest of the system is a recently restored Carver TFM-35 and some upgraded SDA-2BTLs.
2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
Are you using the dac as a preamp on the Carver currently?
I am currently using the iDAC as a preamp but it has no volume control or gain so I guess it's not officially a preamp. My main source has its own volume control and the carver has an upgraded stepped attenuator I use for the device I stream qobuz from as that streamer doesn't have volume control.2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
Ps audio perfect wave dac bridge 2
Used can get around $1500. And it's upgradable to the direct wave dac. And has a volume as a pre amp -
Schiit had a few choices as well as Ifi zen. For that price range, you can get a preamp and dac separates.
RME ADI-2 would also fit that as well. -
Thanks for the suggestions so far, I am looking those mentioned up. Other models I've started looking at are the Cambridge Audio CXN V2, Primare SC15 Prisma, NAD C658, and Arcam ST60, some of these might be a bit above the budget but just trying to see what's out there. I also want to make sure I get something that's isn't a step down from the current Peachtree iDAC but that's hard to know without hearing them.2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
All I can say is that I’ve been very happy with my CXN v2, and it would require probably more than triple the cost for me to replace it.Analog: Hana ML > VPI Prime Signature 21 > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
Discogs -
Another vote for the NAD C658. Make sure you ask about any problems, but I picked one up and it is working great. It's a streamer/DAC/preamp with room correction. Mine also included the HDMI board for less than your budget. Good, neutral sound and transparency.Infinity RS-1Bs / Bryston 7B STs / Sonic Frontiers Power 2 / Jeff Rowland Consonance / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5 -
@engie490 where did you find one with the HDMI board in that price range?2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
ambiophonics wrote: »@engie490 where did you find one with the HDMI board in that price range?
The Music Room. They have a 14-day return option for any reason and 45-day warranty. Thought those were good reasons to buy with them in this particular case.
Drove up to pick it up, so I saved shipping, but sales tax was almost twice what shipping would have been.
Looks almost new and came with OEM box and accessories.
Infinity RS-1Bs / Bryston 7B STs / Sonic Frontiers Power 2 / Jeff Rowland Consonance / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
Schitt Audio Freya S pre & Bluesound Node would fit the bill nicely. Way under your budget with warranty.
From what I read Bluesound really upped their performance of the Node with it's new DAC & connectivity options.
https://shenzhenaudio.com/products/gustard-r26-discrete-r2r-decoder-with-streamer-renderer-pcm768-dsd512-bluetooth-xmos-xu216-high-performance-audio-decoder
I had the Cambridge Audio 851N streamer. This is WAY better. I don't stream per se any more except via my phone and Bluetooth or my laptop and a USB cable. I honestly can't hardly tell the difference between USB and Bluetooth.
ambiophonics wrote: »Thanks for the suggestions so far, I am looking those mentioned up. Other models I've started looking at are the Cambridge Audio CXN V2, Primare SC15 Prisma, NAD C658, and Arcam ST60, some of these might be a bit above the budget but just trying to see what's out there. I also want to make sure I get something that's isn't a step down from the current Peachtree iDAC but that's hard to know without hearing them.
Take a walk on the Arcam… it does not offer USB inputs, and reliability sucks.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Good to know about the Arcam, especially the reliability. Input wise I really only need 2 coax and 2 optical inputs to be happy2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
I picked my perfect wave dac MK2 bridge 2
For $1500 and couldn't be happier. Can be used as pre amplifier. USB ,optical,coaxial and with bridge 2 .
