New to Polk in wall system
akshayn
I recently moved to a house which has Polk inwall system. Now I am a beginner with these things. I see that there is hdmi cable and another cable (can be antenna cable or speaker cable, no clue) coming out of a socket. How do I connect these speakers to my tv ? There are 5 speakers in total. 3 on the front and 2 on the rear. Can someone please help ?
Answers
You need a 5-channel home theater receiver...AVR for short
Example
https://www.bestbuy.com/site/denon-avr-x2700h-8k-ultra-hd-7-2-channel-95-watt-x-7-av-receiver-3d-audio-video-built-for-gaming-black/6421385.p?skuId=6421385
@txcoastal1 thanks a lot for your reply. Do these receivers take hdmi as input ? What is that hdmi cable from the wall socket ?
Is there a closet or a space where you see a bunch of wires? If yes, this is where they had the receiver. That coax is for antenna/cable service, HDMI is for your TV signal from receiver to the TV. Where all these wires go to is where the receiver was located.
Go to link below to get an idea how a receiver works.
file:///E:/downloads/AVRX2700H_EU_EN.pdf2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I searched the whole house and couldn’t find a place where a receiver could have been located or a place where bunch of wires go. The file that you sent can’t be accessed. @txcoastal1
There has to be a hub or a cabinet in the house somewhere
Something like this with a cover
Denon receiver PDF attached to download
The OP is likely in Australia or New Zealand.
OP, there has to be a location where the connections for the in wall speakers is accessible unless they were never connected, which while possible seems highly unlikely.Political Correctness'.........defined
President of Club Polk -
@F1nut yes I am in Australia. How do these connections look like ?
Could be simply bare speaker cable or binding posts mounted on a wall plate.Political Correctness'.........defined
If the wall behind the front 3 is open you should be able to see if there are speaker cables connected to the speakers and be able to follow the cables. If the wall is closed remove one of the speakers to check if it even has speaker cables connected to it.Political Correctness'.........defined
Any plates like this...even on same wall with HDMI
@txcoastal1 just that one in the first comment . Nothing else
Are you the first owner of the home?2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
@txcoastal1 nope, the previous owner does not reply
All I can think of is pull out one of the speakers, and disconnect it. Purchase a low voltage tone generator (wire tracer)
Connect the tone generator to the speaker wire at the speaker. Take the wand which should pick up the tone to locate the speaker wire bundle in-wall.
I do this kind of stuff for a living, but you live a little to far
Tone and Probe Kit, Wire Tracer&Circuit Tester Professional Tone Tracing Kit, Cable Tester Tone Generator Inductive Amplifier with Adjustable Volume
