Relay logic
1eye
A Revox has an example of a kind of logic circuit that predates digital logic but which could be replaced by a few NAND gates (integrated circuits). Instead, it uses the strange wiring harness (which the Larson cartoon refers to), to connect the relays' multiple contacts, so that the push-buttons on the deck's front panel, when pressed, cause the correct motors to operate in the correct directions. If you were to sell such a deck now, it would, like a modern car's turn signal, have a speaker, which would emit the "comfort noise" of the relays clanking over at the same time that the motor(s) started or stopped.
@SeleniumFalcon @mhardy6647 interesting. Above my level.Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Well, I'll take 2- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Failed spammerPolitical Correctness'.........defined
President of Club Polk -
That would be my guess, yes.
and speaking of Larson cartoons...
Didn't realize LSD was still popular. Learn something new every day...
Another vintage logic form...
