What size and how many subs to put in my Civic
Systems
I have a Civic Coupe and I want to change my system around but I need a little advice. The reason I want to change my system around is so have a little more room in my trunk. I want to put my subs and amp below the trunk floor but I will probably have to lift the floor up around 6 inches or so. Currently I have 2 10's plus 3 amps above the trunk floor but like I said I want to put them below the trunk floor and have a little more room in top.
Currently this is my setup:
Amps:
RF 551S 2x140
RF 351S 2x90
RF 501bd 300W(4ohms) 600W(2ohms)
Speakers
Polk 6x9 MMC690
Polk MM6 components
2 sony 10" subs which I plan to upgrade to Polks (the sonys are really bad)
My music tastes range from rap to alternative in case that matters on the sub question.
So my question is do I try to go with only one polk 10inch sub which would fit in the tire well perfectly and not having to raise the floor to much or should I go with two polk 10inch subs and have to raise the floor a fair amount? How much will I notice in the sound difference between the two? I guess if it is advisable to stick with 2 subs them at that point I could go for two polk 12 inch subs, would that be any better?
Also If I go with 2 subs and still plan for having everything below the trunk floor but raising the floor up lets say around 6 inches (the mounting depth for the subs are about 5 1/2) and make 2 boxes the appropriate volume, would it matter that the sub depth is just about the same depth as the box?
thanks for the help
Amps:
RF 551S 2x140
RF 351S 2x90
Speakers
Polk 6x9 MMC690
Polk MM6 components
thanks for the help
Testing
Testing
Testing
Testing
Testing
id get a couple of the 10" momos...the 2104s
if you only get one sub youre only going to be using half the power from the 501bd
If you were into metal and harder rock with fat guitars Id highly recommend a single sub as dual subs are a bit much.
However, given your musical tastes, I agree with Cody but I would recommend the the MM124s. 12s would be a lot better suited for rap. Although you wouldnt really be going wrong with 10s, I would just get 12s if it were me.polkaudio sound quality competitor since 2005
If you want to wait another month, the dB line of subs should be out. They'll also be in DVC
Brian Knauss
ex-Electrical Engineer for Polk
