Polk magnifi 2 stuck and flashing
Chewing
Hello,
It's been a week since my soundbar stopped working. It flashes with all the colors without stopping.
I tried everything, but it goes back to the same cycle every time.
I live in France for information. I emailed support but got no response.
I'll forward this information to a friend at Polk for advice.
"Have him hard rest the bar by unplugging it while it is on, leave it off for a few minutes and reboot it. This should reset the bar.
It may take a few attempts to reset it."
Thanks for your help @SeleniumFalcon. I tried it without success unfortunately. still no answer from polk support 😔
Thanks for trying, I'l forward your contact information to my friend at Polk.
Thank you very much
Hello, my problem is something similar but with a different combination of leds.
green, green, red, green, red blue, blue, blue, white, white.
It will have a solution, in my area there is no polk support. The team is magnificent 2. -
Sounds like it is locked up.
Try reseting the bar by unplugging it while it is on, leave it off few a few minutes, then reconnect it.
You may have to do this a few times to solve the issue. -
Hello I have the same problem than @jsotovalle
I reseted the bar like 20 times and is te same thing
Anyone can solve the problem??? -
I recommend contacting Polk's CS department at: 1-800-377-7655 and they can help.
please tell me how did you fix this problem?
Hello,
did you resolve the issue?
