Speaker Gasket
Removed the 6.5's from my cs1000p center the other night. When I did I noticed some gaskets on them. The one was torn. Where can I get replacement's?
  • jdjohn
    jdjohn Posts: 3,443
    Buy some Armacell foam tape from Home Depot or Lowe's, and cut it to size. Done.
  • DaveHo
    DaveHo Posts: 3,584
    Good recommendation. Make sure it's the thinnest they have, don't need much to create a good seal.
