Hooking up a SVS SB1000
I found a smoking deal on one. These only have RCA inputs. My MF amp has a left and right loop output RCAs. Can these outputs be used to connect the sub? I feel like I should know this....
    F1nut Posts: 52,152
    The loop circuit is for adding an equalizer or other processor into the signal path. You cannot use them for connecting a sub. The good news is the SB1000 has high level connections, so you would run a second set of speaker cables from the amp to the sub from the same binding posts you use for the speakers.
