Velodyne CHT-15 any opinions?
hoopdaaron
hoopdaaron Posts: 16
edited June 2004 in Speakers
Have a chance to pick up a new Velodyne CHT-15 for $375 including shipping. Any opinions on this sub, especially for this price?
I had my eye on a PB2ISD from SVS, although more than I probably needed, the guys at SVS were very helpfull. But when the Velo deal came up, for $600 cheaper, not sure I could pass it up.
thoughts and opinions?
hda
* also posted in the subwoofer forum
Home Theater System
Front - Polk Rti12
Side surround - Polk FXi5
Rear Surround - Polk FXi5
Center - Polk CSi5
Subwoofer - Velodyne CHT-15
Receiver - Onkyo 901
TV - Sony 60" LCD
DVD - Sony 725
Game - PS2 (Optical audio, and Component video)
Power - Monster Cable HTS1000
Interconnects, Audio - Monster Optical 200, or Monster 400MKii
Interconnects, Video - Monster Video 3 Component
Speaker cables - Monster Z3 for front, center - 12 gauge in wall for all rear
  • MSkeezer
    MSkeezer Posts: 1,183
    edited June 2004
    At that price, get it. Sound and Vision recently reviewed that model, along with about 9 others, and the CHT-15 came out on top. Here's what they said:
    "How Low Does It Go?
    •Bass limit 25 Hz at 92 dB SPL
    The Velodyne had 6 to 12 dB higher SPL at 25 Hz than any other sub tested. Translation: It kicks major butt.
    How Big the Bang?
    • Average SPL from 25 to 62 Hz 107.3 dB
    • Maximum SPL 116 dB at 62 Hz
    • Dollars per dB $6.51
    The CHT-15 can produce peak SPLs that beat subs costing three to four times as much.
    The Bottom Line
    The Velodyne CHT-15 delivered the biggest bang of the lot, hitting a tooth-rattling 116 dB max SPL. Its all-black styling can be considered either mysterious or menacing depending on your perspective."
    For $375, you're getting one helluva deal for a kickass sub. Get it!
  • Terrax
    Terrax Posts: 483
    edited June 2004
    I would have to agree with MSkeezer here. Biggest bang for the buck at the price you quoted for the Velo 15. :cool:
  • EricH
    EricH Posts: 140
    edited June 2004
    I have one. Really nice for the price I paid ($500 at CC). For that price I'd pull the trigga!
  • jmierzur
    jmierzur Posts: 489
    edited June 2004
    You should be asking yourself if you can live with the "sound" of the CHT-15 long term. Is this what you want for movies and/or music? Will you be upgrading later to what you should have initially purchased?
    Since you mentioned SVS, did you consider the PB1-ISD or the 20-39 PCi? I listened to the CHT-15 and all other subs in this city. In the end I decided on SVS products. The only other sub I would consider to replace my SVS's would be Velodyne DD-12's.
  • hamzahsh
    hamzahsh Posts: 439
    edited June 2004
    Great deal on Velodyne CHT-15, I'm using mine for about a year. CHT-15 goes really loud and low. It definitely goes below 20hz. BTW, I never measured it but somehow I now it and I can feel it. The bass output is very strong and clean, once I played ROTK and on one scene the bass was so loud that the shampoo bottle fell in the washroom!:eek: No kidding seriously my brother told me when he came out from the washroom. Wow! it really kicks major butt. Also remember to use high quality sub cable. I use Monster THX Ultra sub cable which made a lot of improvement compare to AR HT Pro cable which I was using before.
    It also has a Current Sensing Servo technology which is a steal for the price you mentioned. Normally you get CSS technology in expensive subs. CSS tech keeps the driver in normal position which means minimizing the driver movement from distortions and preventing it form damage during heavy bass signals when more air is pushed.
    Go for it!:D
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
