RT3000P & cs1000P Crossover Rebuid
Denon_Polk
in Speakers
Should be picking these speakers up soon. Was thinking about rebuilding the crossovers before set them up. Has anyone done it before or maybe have the parts list they used?
Hello,
Welcome to the forum!
Are you referring to the bass amplifiers or the passive part of the speaker's crossovers? -
Was looking to do the speakers crossovers but after testing the bass amps. The one is going to need some work also. When turn it on, it's making a loud buzzing sound.
Let me check through my old papers for what I have available. The top speaker of the RT3000p is very much like the RT55i speaker except (if I remember correctly) there is an additional high pass filter not found in the 55.
I found the upper speaker crossover schematic and instructions on how to set the bias on the bass amplifier.
SeleniumFalcon wrote: »I found the upper speaker crossover schematic and instructions on how to set the bias on the bass amplifier.
I found the upper speaker crossover schematic but not how to set the bias on bass amp. -
Using a DC voltmeter place the probes on either side of R103, with the amplifier's speaker wires disconnected from the woofer. Plug the amplifier in and adjust TVR3 to read between 0.5 and 1mV.
I know the rt3000p, cs1000p & f/x1000 are timbre matched but would the cs1000p match with the rt2000i?
Denon_Polk wrote: »I know the rt3000p, cs1000p & f/x1000 are timbre matched but would the cs1000p match with the rt2000i?
It should be as it is still in the RT lineup
