Carver AL-iii plus
I know very little about these speakers, but a friend of a friend has a pair for sale. The price is low as far as I can tell. My room is rectangular 18X12.
My question is what are some requirements for these speakers? Are they difficult to drive? Are they difficult to place? Things I should look for during the demo.
I've had Polks for a while, but I'm tempted to try these out.
Any Carver fans out there? Help me if you can.
    SCompRacer Posts: 9,404
    edited September 2022
    Many years ago, I had AL-III's and the AL-III + that I did the Infinity woofer upgrades on. As I recall, bass was vastly improved with the Infinity upgrades. Great speakers! IIRC the OEM woofers had foam surrounds?? So check them out. The woofers are down firing at bottom of woofer cabinet with spacers then the base plate. A small inspection mirror would be helpful.
    They are a dipole so you'll have rear reflections. Best to have them out 2-3 feet from rear wall. With dipoles you can enjoy the ambience or use treatments to absorb rear reflections. They like a large room. My living room is basically an open main level (like 16' x 40') with high ceilings (14').
    Make sure no ribbon issues exist at low, mid and higher volumes. Like buzzing noises. They are demanding to drive, so you'll do best with a high current amp. What amp do you have to drive them?
    F1nut Posts: 52,406
    Nothing but trouble, walk away.
  • krazypolk
    That settles it.
    As an added bonus he also has some ok looking 2.3tl s. He said 400 or close enough offer. Would this be a better alternative.
    As for amplification, nothing that would knock your socks off. Adcom triple 5.
    txcoastal1 Posts: 13,520
    That would be a better option
    Get that Adcom refreshed and you’re rocking
    Next year you can work on the 2.3 upgrades
  • krazypolk
    The carver guy provided these pictures. Are they worth his asking price or should I try and offer less? They look kinda dusty so he probably aint too attached to them I figure.
  • dkfreebird
    dkfreebird Posts: 1,189
    If they were close to me I would buy them at that price.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    Eversolo Dmp 8
    SVS SB3000 sub
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • krazypolk
    Toolfan66 wrote: »
    $400?? And you don't have them yet??
    I been meaning to drive over, but the seller says that he'd prefer to wheel and deal on the weekend.
  • krazypolk
    krazypolk Posts: 745
    His carvers.
    Maybe he should nt have them sweltering out in the hot sun.
    He said he had a compatible amp for the carvers. Would this amp work with the polks?
  • odcics2
    odcics2 Posts: 396
    My buddy drove his Carver speakers with a TFM-55x.
    I’ve used my TFM-35x to drive Ohm Fs without any issues. 350 wpc into 4 ohms, if required.
    treitz3 Posts: 20,366
    krazypolk wrote: »
    It is a common ground amplifier, so yes. Maybe not the best choice of amplifiers (bright) but yes.
  • invalid
    invalid Posts: 1,560
    Polk 2.3tl for the win. The Carver speakers are like a fine Ferrari, they are pretty, will require an on call mechanic and will require exotic parts from far away places that will cost $$$ IF available.
    Everyone I've ever known who had ANY of the Carver ribbons has had multiple problems with buzz.
    I can confirm this, a friend of mine used to fix the buzz in the carver ribbons, he was always busy.
  • daddyjt
    daddyjt Posts: 3,266
    krazypolk wrote: »
    His carvers.
    There are two versions of this amp, one common ground, and the other "inverting", or non-common ground. To tell the difference, look at the speaker binding posts on the back - If they are red-black-black-red, you have the common ground option (This option will also have a mono-stereo slider). If the posts are black-red-black-red, then it is the inverting model, and NOT common ground. Also, that amp is about 35 years old, and if it does not need service now, it will very shortly.
    ― Aleksandr Solzhenitsyn
    Good call, Mark. I did not know they made 2 different models of the same amp. Thanks.
  • krazypolk
    Thanks for the info @daddyjt. This is a pic of the back panel. According to the info it should be possible to use it with the polk 2.3s.
  • daddyjt
    krazypolk wrote: »
    Correct - that is a non-inverting (common ground) 1.0t. It also looks to be in very nice condition.
    There is a guy in norther Michigan that does fantastic work on them - from a refresh service all the way up to some pretty impressive modifications. He is at https://nelionaudio.com/ He is good friends with Bob Carver, and is fully endorsed by Bob to work on Carver gear.
  • krazypolk
    Thanks for the link. You sure know your carvers.
    Hopefully I can seal the deal with these items.
  • TroyD
    TroyD Posts: 13,124
    The Carvers are intriguing. The ALiii, IMO, is a worthy speaker. The 10” downfiring woofer will need to be refoamed for sure.
    The ribbons are fantastic. A lot of people poo poo on them but Genesis back in the day, employed the Carver ribbon in their speakers…That said, these ribbons do not like humidity and they aren’t made anymore so repair is out if the question for all intents and purposes. …but if the speakers are in good nick, the sound is seductive. As far as price? I wouldn’t pay more than a few hundred for a pair (as the woofers will need surrounds)…
  • TroyD
    TroyD Posts: 13,124
    As far as the amp goes.....my only gripe with the m1.0 was the loud pop when shutting it off.....but, it was/is a nice amp...but, regardless of how nice of shape, it’s pushing 40 years old and is due for service....
  • daddyjt
    TroyD wrote: »
    The turn on/off thump is fixed with any reputable service - it's a relatively easy fix...
  • krazypolk
    Bad news all around.
    I drove over to the seller's house where he informed me that the carvers had already been sold. No big deal to me because I eas having cold feet about them any how.
    He plugged in the polks and began playing some of favorite tunes. He had not listened to them in over a decade and by the time the demo was over He could not push himself to sell them
    WTF. I guess that's the way it goes sometimes.
  • DaveHo
    DaveHo Posts: 3,584
    Maybe offer more than $400? That price is a steal. Double wouldn't be out of line if the cosmetics are good. Likely the best vintage SDA ever made.
  • engie490
    I wouldn't try to figure out how much $$$ will dislodge the speakers from this guy's garage. I would stop playing games with him PERIOD.
    First he says "I want to sell you speakers and some gear, but you have to wait for the weekend." Then you get there and he says, "I sold all of that stuff I was going to sell to you. And I'm not going to sell you these other speakers I offered to you because I forgot how good they are."
    He may otherwise be a nice guy, but I wouldn't want to buy anything from him.
    Just wait and keep an eye on CL and something will pop up. He's not the only game in town.
    Apogee Stages / Apollon Purifi 1ET6525SA / Classe CT-SSP / Innersound Phono / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
