Electrical Code Question?
TheMaster
Does anybody know if dish washer and food processor should have a designated line from a circuit braker? I have a kitchen remodeling project here in CA. and would like to get some feed back from a Certified Electrician or experienced person here in the forum.
The kitchen has a dedicated 20 amps for outlets and a 30 amps for the dishwasher and food processor. It also has a 40 amps for stove.
Glenn
Glenn
HT:
DENON AVR-3803
DENON DVM-1805
SONY DVP-NS300
SONY 36' HDTV Wega
ADCOM GFA-555
ADCOM GFA-555
ADCOM GFA-2535
ADCOM ACE-515
POLK RTi70's (Bi-Amped)
POLK CSi40
POLK FXi30's
POLK RTi38's
POLK CSi20
POLK PSW 450
SVS PB2 Plus
2 CH Stereo:
AudioSource Pre/Amp 1
Hafler DH-500
Sony CDP-CX235
Monster Cable HTS3500
SDA SRS 2.3tl
DENON AVR-3803
DENON DVM-1805
SONY DVP-NS300
SONY 36' HDTV Wega
ADCOM GFA-555
ADCOM GFA-555
ADCOM GFA-2535
ADCOM ACE-515
POLK CSi40
POLK FXi30's
POLK RTi38's
POLK CSi20
POLK PSW 450
SVS PB2 Plus
2 CH Stereo:
Hafler DH-500
Sony CDP-CX235
SDA SRS 2.3tl
Post edited by RyanC_Masimo on
any "motor" is suppose to have a dedicated circuit I assume you talking about the thing in your sink that grinds up food when you say "food processor "
so yes the dishwasher and garbage disposer each get their own circuit
If you are asking about a counter top food processor, it does not need a dedicated circuit.
hope that helps.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Thank you for the info. Hoosier21. Yes I was talking about garbage disposer. Ddo you know any reliable source on the net where I can read more about electrical codes for resedentials?HT:
DENON AVR-3803
DENON DVM-1805
SONY DVP-NS300
SONY 36' HDTV Wega
ADCOM GFA-555
ADCOM GFA-555
ADCOM GFA-2535
ADCOM ACE-515
POLK CSi40
POLK FXi30's
POLK RTi38's
POLK CSi20
POLK PSW 450
SVS PB2 Plus
2 CH Stereo:
Hafler DH-500
Sony CDP-CX235
SDA SRS 2.3tl -
Not on the net, try your public library.Dodd - Battery Preamp
Electical codes are a local kind of thing. What I mean is, since you're in CA, you need to find out what codes you need to follow for where you live.
CA MIGHT have city, county, or state requirements. I don't know, I'm from Ohio. Sooooo, you need to find out who's code you need to follow.Bob Mayo, on the keyboards. Bob Mayo. -
I know here in fla. anyways, you have to have a ground fault outlet anywhere near a water source, like kicthens, bathrooms and outside outlets
edit: opps, i was thinking outlets not large appliances, after i read food processor, don't mind me..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Typically, but not universally, a dishwasher and a garbage disposal are required to have their own dedicated grounded 15 amp 120 volt circuit, minimal. This would mean a run of at least 14 Ga., 3 conductors (or 14/3 wire), depending on the length of the run.
This doesn't mean you can't exceed code, such as running 20 A. circuits, but you'd have to increase the conductor size also, say 12/3. But it would still have to be dedicated.
A quick call to your local code enforcement office would clear it up.
I'm not trying to sound like a licensed electrician, 'cause I'm not. I just have a little experience in this stuff. -
thanks again for the inputs guys
GlennHT:
DENON AVR-3803
DENON DVM-1805
SONY DVP-NS300
SONY 36' HDTV Wega
ADCOM GFA-555
ADCOM GFA-555
ADCOM GFA-2535
ADCOM ACE-515
POLK CSi40
POLK FXi30's
POLK RTi38's
POLK CSi20
POLK PSW 450
SVS PB2 Plus
2 CH Stereo:
Hafler DH-500
Sony CDP-CX235
SDA SRS 2.3tl -
I hate all the NEC stuff. I'll stick to the NESC! (before the meter, anyways.)
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
