Polk RTi6 Dust Cap
The dust caps on my RTi6 speakers are old and have cracked. Are replacements available for these or even new drivers if I have to go that route? I should probably look into getting replacements for my 4's also since they're looking a bit brittle as well.
TIA,
Mike
  • Keiko
    Keiko Posts: 794
    I've been doing some research. Replacing the driver would cost me about 60 bucks. PE sells these dust caps which I think might work for 1.35 plus 8 bucks for a bottle of speaker cement.
    I've never attempted a repair like this before, but it seems relatively easy and straight forward. If anyone has any input or experience, please chime in.
    https://www.parts-express.com/2-1-2-Poly-Dust-Cap-260-382
    VR3 Posts: 29,626
    Those should work.
    I would take a q tip and isopropyl alcohol and put around the perimeter to loosen the glue then gently take a knife to remove the old one
  • Keiko
    Keiko Posts: 794
    VR3 wrote: »
    Those should work.
    I removed one of the old ones and measured around the cone. The actual size of the cap is 1.75in. So those from PE are a little too big. I found these in the correct size, but they're made of polypropylene. The original caps are made of Butyl rubber, same as the surrounds. I'm thinking these should be OK, but trying to find some proper rubber caps before I commit. I contacted polk and it appears their only option would be is to replace the entire driver when all I need is the dust cap.
    https://www.midwestspeakerrepair.com/shop/speaker-repair-kits/dust-caps/polypropylene-dust-caps/
    pitdogg2 Posts: 27,547
    edited September 2022
    Put your grill on Mike and stop stressing it'll be fine.... B)
    Getting them off is the hardest part putting them on is the easy part. put speaker flat on it's back, Glue, drop on walk away for 12hrs... easy peasy.
  • Keiko
    Keiko Posts: 794
    Hey there, Ivan. I just went ahead and bought a pair of poly caps from Midwest Speaker. 17 bucks & change vs 120.00+ to replace the drivers. The job appears to be pretty straight forward and simple, but leave it to me to botch it. BLAH! ;)
    Weird that the rubber just disintegrated on these. Must be the salty air and humidity we have here.
    heiney9 Posts: 25,576
    Living in Paradise has it's drawbacks...... :D
    I'd take a little salt corrosion occasionally to enjoy the great weather and beautiful scenery.
  • Jstas
    Jstas Posts: 14,999
    heiney9 wrote: »
    A little, huh?
    Never been to Hawaii, have ya?
    I had locals tell me the dirt is orange because it's not actually dirt but rusted old cars and patio furniture.
    Expert Moron Extraordinaire
  • Keiko
    Keiko Posts: 794
    Jstas wrote: »
    heiney9 wrote: »
    A little, huh?
