Rt55i Crossover Upgrade
Hello, so I just picked up a pair of Rt55i. I generally love the sound, but there is very faint distortion. I assume it must be the crossovers because it happens with both of them. One of them is more noticeable than the other. They are in great condition, and I love the sound generally. The sound is ever so slightly off, but when listening really close it's somewhat noticeable.
In sum, I would want to know how to replace the capacitors and resistors. I feel like there would be no point in buying a used set of crossovers since I would probably run into the same problem before time.
Any advice is appreciated. Mainly, a how to on getting the right parts. I searched a round a bit, and was still left a bit confused. Or if there is a list of what I would need to buy, that is perfect. Where to buy from, etc... Thank you!
    pitdogg2 Posts: 27,372
    First you look at your crossover to get the information from the components Polk used. The RT55i schematic has been lost or unavailable for awhile now. Looking at your XO could very well help you diagnosis your problem. It will give you values you need to order parts.
    F1nut Posts: 52,027
    First you need to determine where the faint distortion is coming from, the tweeter or drivers.
  • Okay, so I found a picture on ebay. It looks like it will take 9 MFD 50 V and 16.5 MFD 50 V...
    Can the voltage on the replacements be higher? What about the uf value too? Do I need to care about the resistors? Haven't had a chance to take the unit apart, but I am going to replace them one way or another. Thank you!
    F1nut Posts: 52,027
    Voltage can and will be higher with poly caps. The uF value should be the same as stock. Yes, replace the resistors with Vishay Mills.
  • phillip559
    phillip559 Posts: 24
    edited September 2022
    Got it, thank you. I was able to find capacitors. I see there is a 5w 2ohm resistor, but the other one says 5w 3ohm 5j... does that require a specific type? I have only been able to find ones with w and _ohmj not _ohm _j. Also, the yellow 3.0j 100v is?
  • Gardenstater
    Gardenstater Posts: 4,804
    The yellow is a 3.0uF 100V film capacitor (tolerance unknown) and the other resistor is 3.5 Ohm which you would replace with Vishay Mills which are wirewound non self inductance types. There are other options for resistors of course and many are more expensive.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • WLDock
    WLDock Posts: 3,073
    Yes, those are basic 5 watt, 2 ohm and 3ohm sandcast / ceramic style resistors. Those are the only values you need to be concerned with. F1nut is suggesting that you upgrade to better Vishay Mills brand resistors. Its totally subjective and you decide if the extra cost is worth it to you.
    The yellow component is a 3 μF (micro Farad) 100 V Mylar poly style capacitor. There are several old threads on this subject with pictures, the schematic, discussion, etc. I have linked a couple here:
    RT55 crossover schematic: https://forum.polkaudio.com/home/leaving?allowTrusted=1&target=https://us.v-cdn.net/5021930/uploads/attachments/9/9/3/4/4/46071.pdf
    https://forum.polkaudio.com/discussion/163764/rt55-crossover-refresh
    Walt Thanks I've been on the hunt for that schematic !
    To the OP going up in wattage value on the resistors is just safe insurance. When you're looking at about $4-$6 each and only a about .50 to $1.00 in difference go with the higher 10 or 12 watt Vishay Mills or Mundorf resistor.
    F1nut Posts: 52,027
    phillip559 wrote: »
    Some use alphabet letters to indicate the tolerance. In this case J means +/- 5 %.
  • WLDock wrote: »
    Not nitpicking I just don't want the OP to get the wrong resistor. The 2nd one is 3.5 Ohm not 3 Ohm.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • phillip559
    Thank you everyone for the replies! It has helped a lot. I purchased a set of xo on ebay for $23. Figured it's hard to go wrong at that price, and probably don't see that deal often lol I replaced the xo on the speaker that had more prominent distortion. It definfely helped. I am still going to go ahead and do the upgrade since they will benefit regardless. Love the sound on them so worth the upgrade imo.
    There were a number of black spots and the glue was a complete different color than on the replacement units. Does that mean they were running too hot?
    Actually, it is evident. The glue melted down. The replacement units definitely do not look like that. The speakers appear to sound fine... how is that so?
