Why Is My Polk Audio Amr130 Popping?
OldLinuxDistros
So My Windows 7 Computer Has No Speakers Then My Dad Gave Me His Old Speakers And They Still Work But They Were Popping But I Found A Date On The Speaker And I Don't Know What Is Means And It Says (11/2001) So Then In 2019 It Popped And Then I Played A Song And It Popped And Turned Off Someone Help Me Please
Comments That Are Not Helpful Will Be Deleted
Answers
For Sure It Was Left In That Closet You Know Just Unplugged And Nothing Else
The AMR130 has smaller satellite speakers and a woofer. Which part is popping?
The Normal Speakers And I Have To Turn The Woofer On Then Turn On The Normal Speakers But Please Help (I Took It Apart Please Don't Say I'm Crazy)
The popping sound is probably coming from a defective amplifier.
Your crazy
turn the volume up full blast. Turn it on & see what happens. Report back
JokingRandy/Maine . RTA15tl - Cs1000p -
Well I Found A Big Capacitor I Think It's What Caused The Polk Audio To Pop And Turned Off For A Little Bit
Which Linux distribution makes every word capitalized like that as you type?
The same one you used to use that put the reply above the quote2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
lol! Well played, but you gotta let that go!
It's My New Way To Type Cause I Used To Type Wrong But I Made It Better -
txcoastal1 wrote: »The same one you used to use that put the reply above the quote
What Are You Talking About I Mean It Pops Then Turns Off For A Little While But It's Old I Think It Was Around November 2001 -
I would recommend checking to make sure the power supply rectifier diodes are installed with the correct polarity.
SeleniumFalcon wrote: »I would recommend checking to make sure the power supply rectifier diodes are installed with the correct polarity.
What Do You Mean By That? -
Ya gotta stick the ying yang in the dim sum then connect the yak jack to the dilithium crystals until your drive is warped. If that doesn't do the trick jump down into the alley and fire up a fatty.Political Correctness'.........defined
President of Club Polk -
thiS threaD iS likE aN episodE oF "thE twilighT zonE".
