Need Help BADLY
Systems
Systems Posts: 14,873
edited June 2004 in Car Subwoofer Talk
I just bought two polk mm2124's. they are 400 watt rms and 800 peak. i am looking for a good cheap amp that will work for these. Im think about either a Hifonics Brutus BX1000D or Jbl Bp600. I like the jbl because its cheaper but is it worth it? please help
Testing
Testing
Testing
  • exalted512
    exalted512 Posts: 10,735
    edited June 2004
    im partial to HiFonics myself, but JBL makes quality amps too
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2004
    Myself, I like MTX, Kicker, Orion and JL Audio amps a lot so for $500 I would recommend this MTX Thunder801D. Its rated at 400x1 or 800x1 but be careful with the gains as MTX amps are freaking powerhouses and this thing is putting out a lot more than its rated.
    MTX is my favorite for $350and down, with Kicker in at 2nd
    Orion is my pick for $350 and up with JL tagging behind
  • Systems
    edited June 2004
    The brutus is too small, unless you get the bx1500d....
    2 4ohm subs can't get a 1ohm load.......
    I'd go with the bx1500d for headroom for future upgrades....
    oh yeah MTX doesn't put out "alot" more than its rated......just a bit. Same as kicker......
    Testing
    Testing
    Testing
  • exalted512
    edited June 2004
    the brutus 1000 will do 50 watts under, the 1500 will do 50 watts over...either or is pretty good
    im sure the 1000 will probably put out more than 800 watts at 2 ohms anyway
    -Cody
  • Systems
    edited June 2004
    -Cody
    oh my bad........I thought it put out 500w@2ohm
    Testing
    Testing
    Testing
  • exalted512
    edited June 2004
    were not total retards here on the polk forum...;)
    -Cody
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited June 2004
    I have always had good experience with Kenwoods, but that's only with the smaller 4ch ones i use. I'd reccomend Kicker if you wnat cheap power, but I wouldnt kill em, they arent the sturdiest.
    -Jerry
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
  • MacLeod
    edited June 2004
    Well hell partner, dont take my word for it.
    Take a gander at Performance Auto Sound review of the MTX Thunder942. Its rated at 235x2 at 14.4 volts but put out 295x2 at only 13.9 volts. Thats 60 watts per channel more and at a lesser voltage. Thats A LOT!
    For a second opinion check out this Carsound & Performance review of the Thunder500D which is rated at 250 watts at 4 ohms and 12.8 volts. At this level, the MTX put out 456!!!!!!!!! Now thats an AWFUL LOT! Its also rated at 500 at 2 ohms but at 14.4 volts put out almost 1000!
    A little while back there was a guy that posted on here with a MTX 4 channel that was rated at 25x4. We gave him a hard time about it and he posted the birthsheet which rated the amp at 55x4! Not to be redundant but thats A LOT! (I searched forever but cant find that damned thread)
