Help For Old Eyes - USB Microscope
SCompRacer
I'm getting old. Trifocal glasses, got some cataracts growing so it's hard to see soldering SMD parts, even with a lighted magnifier. I picked up a crutch, an Andonstar AD407 for ~ $220. 7" screen, adjustable LED lighting, remote control to access menu and snap pics without shaking the thing. All good now, but up close my soldering looks ugly...lol
The "Potato" isolation chip is actually 1/4", or .250 long. Leg spacing like razor blade thickness.
U4 is a tough one...
That's awesome! Not a bad price either- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I like that a lot. I saw a guy repairing a tablet power port with one of those. Made it look really easy, but when you see what size it really is... Still takes some real skill!
Loved the stylus photo. Same thing?I disabled signatures. -
Yes, figured I'd try it though that's not what its for. I've seen better results with just a USB microscope with no screen, but I still got some detail. I didn't get as good results with my microlinear stylus.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
oooh, what's a microlinear look like?
with this microscope, can you see any detail in record grooves?I disabled signatures. -
It depends on the lighting to catch the angles of the stylus. This is my AT33PTG/II stylus. It's mounted on an air bearing linear arm. I'm not sure if this USB scope has the power or resolution for grooves. While we can see the stylus, we could use higher resolution.
that's pretty good!
what's that goopy stuff in the upper stylus photo?
I had something similar to your photo above back when I was first getting into turntables. I was having a strange channel imbalance. I didn't have a USB micro, but used the macro on an old Nikon digital.
Man that is cool! Love the workmat too!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
