SDA 1 Cabinet rattle
Hi Everyone,
My right channel SDA 1 speaker has developed a rattle at loud low frequencies, typically experienced with action movie soundtracks.
I can't complain, this is the only problem I've noticed with these speakers in 35+ years.
Any recommendations for diagnosis and repair?
Many thanks,
Michael
  • Gardenstater
    Gardenstater Posts: 4,799
    You probably have a magnet that shifted and voice coil may be rubbing at certain low frequencies with prolonged tones. I'd check them all carefully with fingers spaced around the dust cap and listen/feel for scraping.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Gardenstater
    ^^Now that coffee has taken affect........a rattle could also be a cracked or torn spider
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,931
    Hi Everyone,
    Many thanks,
    Michael
    A rattle sound is one thing, a popping sound is another.
  • Schurkey
    Schurkey Posts: 2,122
    edited August 2022
    A rattle at low frequencies/high volume seems to me to be more-likely a cabinet air-leak, leading to over-excursion of the midwoofers. Easily and non-invasively tested via the usual "push the bassive radiator, see how long it takes for the midwoofers to retract."
    Otherwise, I think you're gonna pull some drivers out, maybe move or remove the Dacron, and look for loose bracing, or wires rattling against the inside of the cabinet.
    Remember, after 35 years, those speakers need some repairs/updates. The Dacron is almost certainly pulled down by gravity and needs to be lifted back up into proper position, and the electrolytic capacitors are WAY beyond their expected service life. There's plenty more that can be done to improve them, but those two are essentially guaranteed to need attention.
  • skipshot12
    skipshot12 Posts: 2,090
    Probably not related but…
    I had a rattle @ certain frequencies in one of my kappa 8’s.
    Took out the woofer to have a look. Found one of the inductors was loose, one edge not attached.
    A little metal set cured the rattle.
