Tweeter replacement for RTA 12B. This question may have been answered a thousand times before......
Hi all. There's so many opinions or different answers on this. I've called polk customer service and they say there are no current replacement parts for the RTA 12B because it's so old now. Just look on ebay they say. Well, that's all good, but what would be the closest replacement tweeter for the 12B to try to get a hold of from ebay? The ones I have right now are perhaps the Peerless and seem to have the little hole in the middle of the dome. They do work, but I'd like to be able to have an idea of replacement parts just in case.
Thanks to anyone who replies.
Answers
  • Gardenstater
    Gardenstater Posts: 4,804
    edited August 2022
    There isn't anything that I would attempt to substitute for the Peerless and ebay was the correct answer. Just make sure you get the 8ohm variety and try to get one from a Polk and that it has the hole (nobody else did the hole mod). Make sure they pack it in non-shedding material with a hole in it to protect the dome. I had a knucklehead on eBay send me one that had styrofoam particles and chopped glass fibers all over the sticky dome :s Was a lot of work to remove them one by one with sticky tape. It would've been so easy to just stick the tweeter first into a sandwich bag.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • dinocgeo
    dinocgeo Posts: 8
    edited August 2022
    Thanks for replying. So the peerless "copy" or any other from Midwest Speaker Repair are not up to par with the original Peerless I guess? Don't seem to be many originals floating around at the moment.
  • Gardenstater
    It will not have the hole. Aside from that I don't know anyone that has taken a chance on those made in China "copies".
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited August 2022
    I see a few but those don't have holes. Here's one that looks good except for a very slight crease that shouldn't affect SQ at all: https://www.ebay.com/itm/144645015288?hash=item21ad83c6f8:g:74YAAOSwrsViz2zs
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • What was/is the purpose of the hole?
  • I see a few but those don't have holes. Here's one that looks good: https://www.ebay.com/itm/144645015288?hash=item21ad83c6f8:g:74YAAOSwrsViz2zs
    Thanks for that. I see that it's a "5514" I wonder if that would have a slightly different sound compared to the 7514...
  • Gardenstater
    Well depends upon who you talk to but I tend to prefer Polk's own advertising copy for my explanation. Note they hurt their credibility a tad by misidentifying the thing as an SL1000 LOL:
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,417
    Talking about the Wuhanless?
    pitdogg2 Posts: 27,349
    If the peerless you buy doesn't have a hole you can always add one. Polk used a soldering iron the burn a hole in the dome.
  • xschop wrote: »
    I don't know what that is.
    Tony M Posts: 11,734
    edited August 2022
    Here's all you will need to read to understand what they are. ;)
    They are pretty good and cheap domes to replace certain old polk tweeters (SL2000) but unfortunately, I don't think they can replace Peerless domes in their magnet structures.
    https://forum.polkaudio.com/discussion/168239/a-real-sl-2000-hack-replace-stock-burnt-voice-coils-with-silk-diaphragm-dome/p1
  • Gardenstater
    dinocgeo wrote: »
    If the dates of manufacture are close and the DC resistance measure very close or the same, that is all I would worry about.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • dinocgeo wrote: »
    I read that the 7514 was manufactured in Demark and the 5514 in the USA but they seem to be the same tweeter.
  • Gardenstater
    dinocgeo wrote: »
    dinocgeo wrote: »
    Well I have been gathering info. on that....mostly eBay seller's pictures.......and I have pictures of 7514s that also have a Made In USA sticker on them, and I have 5514s that are date coded before manufacture was taking place in the USA at all.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • dinocgeo wrote: »
    dinocgeo wrote: »
    I'm tempted to buy the one on ebay, that you found, just not sure right now in case it doesn't have the same sound. They look identical in everyway though.
  • Gardenstater
    edited August 2022
    Compare the date codes and the DCRs. If they are close I wouldn't worry. If the dates aren't close you could still buy a matching pair of Peerless as long as the DCRs are close to your ones currently in the speakers.
    PS: the date code on that one on eBay I gave the link to is 5th week in 1982 and he measures 7.6 Ohm with a fluke DVOM.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • The manufacture date is the same year...5 months apart
  • Gardenstater
    Not too far apart. DCR is most critical I'd say. I've bought some that measured as low as 6.8 Ohms and that is not a match for the ones I had that came with my speakers, which measured about 1 Ohm higher, and they did indeed sound brighter.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
