Rear Speaker problems (RM7200)
rmhughes0711
rmhughes0711 Posts: 15
I'm having some problems with my Rear speakers on my RM7200. I hooked up the system to my Onkyo TX-SR701 yesterday and my fronts, center and subwoofer are all fine. I get nothing out of the rear. I have connected in the following manner.
Fronts to Subwoofer
Subwoofer to Onkyo
Center to Onkyo
Rear to Onkyo
I have chosen every listening mode on my receiver and checked the connections, but still get nothing out of the back. Every thing else sounds great!!
What am I missing?
Richard M. Hughes
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2004
    The first thing you need to do is rule out either the speakers or the receiver. Try either:
    - hooking up another pair of speakers to the rear on that receiver and see if they work
    or
    - hooking up those speakers to another receiver and see if they work...
    most likely the issue is with the receiver and not the speakers, but it would be helpful to know fur sure...
  • rmhughes0711
    edited June 2004
    Update -- Bad connector on my Monster cable caused the problem. All is well, now.
    Richard M. Hughes
