Distortion on RD0194-1
Hi everyone,
I have just completed restoring (and modifying) a beautiful pair of Monitor 7Cs in black with the original stands. I ordered a pair of RD0194-1 tweeters to replace the SL2000s. Oddly, one of them sounded "off". The distortion became evident when playing music with a keyboard, in particular a Rhodes Phaser. Instead of a clean spacey sound, it had a buzz on certain notes and chords. I heard the same distortion once before on my Monitor 5 Series 2 speakers that I purchased new in 1992, and the dealer installed a replacement SL2500.
This time I was more inquisitive, so I removed the front plate, which includes the dome and voice coil assembly. The problem was obvious -- a few tiny metal shavings (like finely ground peppercorn) had made their way into the voice coil gap. It required some work to get them out, but afterwards everything sounded great. I am glad the solution was easy and I wanted to share it with you in case you experience the same problem.
Regards,
Brian
    xschop Posts: 5,658
    edited July 2022
    QC is lacking nowadays. Glad you got them rectified. Never seen 7Cs in factory black myself.
    Post edited by xschop on
  • decato
    decato Posts: 189
    xschop wrote: »
    Here's a picture.
    xschop Posts: 5,658
    Thanks for sharing. Those would be the 7s I'd mod up. Is there a factory brace front to back on those?
  • decato
    decato Posts: 189
    xschop wrote: »
    There's no bracing. Ideally, there should be one from front to back between the driver and passive radiator. The problem is the crossover is mounted higher up in this series, right where the brace should go. You can install two braces instead, one on each side of the crossover.
    xschop Posts: 5,658
    Ok. That's the same obstacle I encountered on the 5B's crossover position. One mod I still want to do on RD0's is stuff the chambers between pole-piece and magnet IDs with lamb's wool and see if that smooths them out as well.
