Once upon a time in Odyssey Audio land...
ALL212
Couple years ago I bought the Odyssey Audio Liquid speakers.
Klaus told me they might be a bit boomy and he was working on a solution.
I haven't had an issue with them but when he called and said he had upgrades I said yes.
The upgrades are new inductors, new tubes in the base section and a bit of a cabinet change.
I took her bottom off...
. First mod was to remove a panel that was installed in the bottom, then pull the short tube and install the longer one. I've removed those wire tie downs - I thought they were a good idea but they just got in the way.
The inductors... original was a nice copper foil inductors, 3.3 uf,14 g and .421 DCR. New ones weigh in just under 5 lbs each, 2.7 uf and....wait for it...wait for it... .07 DCR.
The original inductor was installed on the crossover board but this new one would crush it. So new mounting required. The extra wires are to assist in reconnecting the crossover to the speakers - Klaus likes 'em short...too short! Inductor wire placement is certainly not final.
Since I had it cracked open I've decided to go 100% Mundorf and parts are coming in.
The wires in the speaker are ready. More to come.
Aaron
Enabler Extraordinaire
Very nice Aaron.
Always wanted to hear his speakers- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Honestly, I didn't even know he even made speakers.
I could be wrong but I believe the ones above are inspired by the symphonic line rg5
https://kahlaudio.com/product/symphonic-line-rg5-reference-floorstanders-lots-of-positive-reviews-22000-msrp/- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I think his entire line of electronic devices all have roots with Symphonic. If you know what the guts of the amps and pre’s look like you’ll see those components in Symphonic amps and pre’s.Aaron
Enabler Extraordinaire -
Klaus is not good about advertising anything or even keeping the web site up to date. He can hardly keep up with word of mouth sales and upgrades
Aaron
Aaron
Where you is?
A LOOOG drive.... from both of you. middle of nowhere upper Illinois, close to Wisconsin
Just take the family jet!
Only 10 miles south o’ the cheddar curtain, right in da middle.Aaron
Aaron is 1:30 Northwest of me.
I've been there and heard that! Great stuff! Nice work buddy! Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
As always, nice tinkering! I don't think I've heard those?
Trey will drive. This time? I am strapped the hood collecting bugs in my teeth. That MF will drive half the way across the country to hear or pick up something. He's legit cray-cray but don't tell him I said that or I will be strapped to the underside of his car.
Someone must guard the catalytic converters.... besides you have high speed hair😜He's legit cray-cray but don't tell him I said that or I will be strapped to the underside of his car. -
I believe the farthest I have traveled is 23 hours round trip for Audio purposes (by car)
0.68 +/- 2%?
Or Mike/Ike black licorice.I disabled signatures. -
Yep.. that’s a silver, not gold band on #3.
I ordered and installled 6.8’s
Treble is rather subdued.
.68’s on order.Aaron
That first band looks like Violet. Then again, I'm partially colorblind. Dear wife or an Ohm meter are never far away when I am working with resistors.
Ya… I screwed it up. Parts inbound.
2nd speaker is on the bench.Aaron
Got any mono albums?
Sounds like they're "ALL" mono now.
.68 instead of 6.8 makes quite the difference. Will get the oops on the bench tonight and flip out the mistake.
Mounted the resistors on the bottom of the board. Cut up screw anchors for standoffs.
Now for break in time…
Aaron
I would be very curious for you to throw some Path audio in there- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I’d have to take out a loan!! I thought I was being extravagant with the mundorfs!Aaron
Seriously worth it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The “DiMM” was the tech not paying attention.
Brain knot - I measured that at .8 and could not figure out it wasn’t 6.8.
Duh…Aaron
