2.3TL tweeters loose output at high power
Got a really nice set of the late model 2.3TL. Running with a Sansui G9000. Lately when I push them hard, the tweeter output gets low, maybe 1/2 of what it should be, turn it down and they will come back to life. It started doing it on one speaker, now it seems like both do it.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    You're tripping the polyswitches, it's too loud.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Astrl55
    Astrl55 Posts: 68
    I concur with the above assessment, and would note that these can fail in such a way that they trip prematurely or unpredictably.
    It may be time to bypass as per a procedure discussed hundreds of times in this forum.
    Toolfan66 Posts: 18,191
    All of the above, I will add that it may be time to just upgrade the crossovers...
  • Emlyn
    Emlyn Posts: 4,832
    If it hasn't already been, it may also be worthwhile at some point to get the receiver a "tune up" to make sure everything's working in spec. Start with the speaker tweak though.
  • Ok, I agree sounds like a polyswitch problem. Why don’t they show it in the crossover schematic?
    pitdogg2 Posts: 27,343
    edited June 2022
    They do, listed as safetyguard. RXE135 IIRC is 1.35amp or part number. Many of us remove and use a good resistors in their place. Another name for them besides poly switch is thermistor, which is what they actually are.
    F1nut Posts: 52,011
    edited June 2022
    Define pushing them hard as it relates to the clock position on the volume knob.
  • motorstereo
    motorstereo Posts: 2,371
    ^^^^^^^^In with 2 o'clock
    F1nut Posts: 52,011
    edited June 2022
    Since the OP was on the forum this morning after your post and still hasn't answered my question I believe you nailed it.
    OP, turn it down or get a much more powerful amp.
    xschop Posts: 5,417
    What's wrong with a 15wpc Crown at 2 o'clock?😂
    txcoastal1 Posts: 13,519
  • motorstereo
    xschop wrote: »
    I believe the unit is a 160wpc Sui g9000 receiver. At 2 o'clock it will trip those breakers.......at least it would when using my g8000 on my 2.3s many years ago
    xschop Posts: 5,417
    Sorry. Inside joke only F1 would understand.
