Cabinet/Driver Resonance Tweaks for SDA-1Cs
I've heard in this forum and elsewhere about resonance deadening of SDA drivers and cabinets. Specifically, using Dynamat X-treme on driver baskets and lately, using Sonic Barrier behind the midwoofers in two four-inch strips.
Does anyone know specifically what frequencies I'm treating by these tweaks? Will I get a smoother, flatter frequency response characteristic of modern loudspeakers from these changes?
Polk SDA-1Cs with RD0194-1 upgrade tweeters, SoniCaps, Clarity PX, Gimpod boards, Cardas BPs, Erse inductors, Canare 4S11 IC; Michi P5; Yamaha M-80; Yamaha CD-S1000; Oppo BDP-95; Sony UBP-X800M2; EverSolo DMP-A6; Topping DX-7 Pro +; Technics SL-1400 with Ortofon 2M Bronze PnP; PS Audio Dectet; AudioQuest Red River ICs; AudioQuest NRG-Z3 PCs; RapcoHorizon High Def High 413-Strand 10AWG Speaker Cable; Auralex Isolation Pads
  • Gardenstater
    Gardenstater Posts: 4,855
    edited June 2022
    You will get less distortion. You don't want the speaker baskets to be energized at all because that is going to find its way back to the cone and interfere with its movements that should ONLY be from the primary musical signal.
    You can't stop that energization from occurring but you can reduce the amplitude of those vibrations greatly and make them die out sooner (reduce ringing) with a material like Dynamat Xtreme which is actually a constrained layer dampening material because of the aluminum skin. Does it change the resonant frequency? I'm sure it does but I'm not sure if it raises or lowers it. That's not the primary goal.
    You will hear drums like tom toms and congas like you never did before the mod. The tone will be different and there will be faster rise and decay times. At least that was my experience. So it is in those frequencies that the primary improvement lies I believe.
    So I don't take heat for a long winded explanation (too late probably) the effect of the Acoustical Foam material behind the MW is to absorb some of the backwave that would've had a chance to reflect off of the cabinet walls and back on the rear of the cone which will produce distortion as well, reducing clarity.
    My Armacell Foam mod inside the baskets does something similar but works at a closer distance to diminish the reflections from inside the basket.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    F1nut Posts: 52,142
    Black Hole 5 is better than Sonic Barrier.
    To answer your question, it cleans up the mid-range frequencies.
