SDA 2 crossover
I took apart a pair of SDA 2. I did not label left or right crossovers as I took them apart unfortunately. With the photo link above I hope someone can tell me if there's a difference between the left and right crossover or it doesn't matter. The fact that there is a left and a right on the speaker though I would imagine there must be a difference.
Best Answers
  • Gardenstater
    Gardenstater Posts: 4,785
    edited June 2022 Answer ✓
    Should be able to figure it out from this. It may be just that you have to connect to the IC jack properly. The SDA drivers (tweeter plus MW) are to the outside edge of each speaker. The inside edge has (from top) stereo drivers tweeter, MW, woofer
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    F1nut Posts: 51,873
    Answer ✓
    steveeray wrote: »
    When I first started the project I thought I saw an upgrade for the tweeter and placing a resistor.
    The TL upgrade is not possible on every model. Yours is one of those that it is not. BTW, it's a capacitor not a resistor.
Answers
