Big Bottle Audio BB3 Tube Phonostage
  • jdjohn
    jdjohn Posts: 3,462
    John, these are built, by hand, in the UK, so subject to exchange rates. I would count on about $1,500 USD (including shipping), but, of course, the seller will have the official selling price.
    Although I haven't seen any direct comparisons to Herron tube phono preamps, I think the performance is in that latitude...and for less $.
  • Firebottle
    Firebottle here, the BB3 designer. The 6DJ8/ECC88 and the 7DJ8/PCC88 operate exactly the same apart from the heater voltage.
    The 6DJ8 is 6.3V heater, the 7DJ8 is 7V. The BB3 operates at 7V for the 1st and 3rd stages so needs the 7DJ8/PCC88. The second stage required a high gain valve hence the use of an ECC83, this operates with a 6.3V heater fed from the 7V heater traces.
    A 6DJ8 'circuit' will work just as well with the 7DJ8, providing the heater voltage is correct. Almost any valve 'could' be used in a phono stage but some are better suited than others.
    The BB3 circuitry includes tricks to make the valve work in a much more linear fashion with a 'triple stack' circuit for the first stage, unlike the majority of phono stages that use a more generic approach.
    Also included in the design is a novel MC/MM switching technique that avoids a mechanical contact in the direct cartridge signal path. This is believed to be unique.
  • jdjohn
    jdjohn Posts: 3,462
    Enjoying mine quite a bit! I made two pair of RCA loading plugs to get me down to 20 ohms and 80 ohms for a few of my MC carts.
  • bigbottle
    bigbottle wrote: »
    How are you getting on with it?
    How much does a build like this run?
    If you'd like to send me a message, I am happy to talk to you about it....as long as we aren't breaching any forum rules 👍
  • bigbottle
    jdjohn wrote: »
    That's great to hear. It's always very rewarding to know it's doing good work. ☺️
