Center speaker
Hi, i have hts 10 subwoofer and s10e and s15e speakers. Should i bug s30c or s30ce center speaker? I thought that s30 without c or ce is older and with c and ce are same but in one store ce is 170e new and c 299e. Im so confused now
Looks like you are referring to the "Signature" and "Signature Elite" lines from Polk and you have the updated Elite version of the ES10 and ES15? If you can get the ES30 Signature Elite speaker for less than the older S30 version I say get the newer version! I would also say get the ES30 anyway since it matches perfectly with your other speakers cosmetically.
The Signature Elite ES30 is $299 in the US market. The older Signature S30 is getting more difficult to find new but the lines will coexist in the market for a while until the old stock is gone. The old models are usually the ones on sale. Maybe the store made a pricing mistake.
https://www.polkaudio.com/en-us/product/center-channel-speakers/signature-elite-es30 -
I made phonecall to store and they said that discriptions are right. Pictures maybe not. Here is pictures:
First speaker is 299€
And why dimensions are different
And yes i have elite versions
The size in the first speaker is consistent with the ES30. The second one’s dimensions are too small to be a center speaker from the Signature lines. Seems like it may be for a bookshelf speaker model.
the size of the second speaker is the same as s10e . So i think second one is really signatue elite es10. S30CE (signature elite es30) is 299 in all hifi stores.
Yes. Size of second speqker are samrThe size in the first speaker is consistent with the ES30. The second one’s dimensions are too small to be a center speaker from the Signature lines. Seems like it may be for a bookshelf speaker model.
But at the bottom of the description size is correct and all other information is correct except the upper dimensions. -
Well i can order that cheaper to store and pay that when it arrives to store so i dont have to pay that before i see that.
Now i made that order and one guy from srore msg me that its not elite so its older version without black centers in elements. But s30CE means s30c elite ? So there should be s30 or s30c without E.
My front speakers are S15E. Should i buy that S30 for 169€ or elite version for 299e?
Are there 3 versions? Example s30, s30e and es30?
