Sda midrange speakers not working
I have a pair of sda 2 speakers . I hooked them up to a used receiver and the left speaker was only working tweeter,no midrange no bass. I thought must be something wrong with receiver but when hooked back to my yamaha receiver same thing, just tweeter. I opened it up and removed wires from mids and plugged into a bookshelf speaker and it was working. Any suggestions? The speakers are mw6510
    pitdogg2 Posts: 27,576
    Drivers are cooked
    xschop Posts: 5,665
    Frozen magnets if they ohm out.
  • DANYL55
    DANYL55 Posts: 6
    Is there a fix?
  • DANYL55
    DANYL55 Posts: 6
    Is it possible the used receiver caused the problem since they were working fine before that?
    xschop Posts: 5,665
    Do the cones on the MWs move freely by touch?
    edited May 2022
    DANYL55 wrote: »
    No. Sounds like you moved them and the magnets have shifted. Since yours are 3rd gen they should still get the sub-bass signal even without the SDA cable hooked up. 1st and 2gen if the blade/blade cable was not hooked up the SDA drive would not work. You stated your driver is MW6510 sounds like SDA2a, those are notorious for killing receivers not the other way. The reason they are hard on receivers is the are 4ohm speakers and drop to low 3.1/3.2 ohms. That is really tough on anything less than a good amp rated for 4 ohm speakers.
  • DANYL55
    DANYL55 Posts: 6
    Yes they do-is it odd that both mids in that cabinet went bad at same time?
  • DANYL55
    DANYL55 Posts: 6
    Yes I always used them without the interconnect cable they actually sound better
  • DANYL55
    DANYL55 Posts: 6
    My receiver is a yahma R1000
  • Gardenstater
    Gardenstater Posts: 4,858
    I'd say you need to get out your meter and do the checks in the SDA Handbook, and check the drivers individually like xschop said.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
