psw250 hookup issue
seavey99
seavey99 Posts: 3
edited January 2002 in Technical/Setup
My new technics receiver has a sub-out but the PSW 250 as
left and right line level inputs. Should I get a Y adaptor to hook up to the sub or can I just hook to the left input? I seem to get good sound by only hooking to the left input of sub. Leave any info on this if you have it! I'd really liked to hear about it as i'm new to owning a powered sub.
Post edited by seavey99 on
  • Firerider58
    Firerider58 Posts: 95
    edited January 2002
    Look at the back of your sub. To the right of the right and left line level inputs, you should have an input marked LFE. Run a subwoofer cable from your sub-out on your reciever, and plug it into the LFE input. That should do it for you!
    Ron
  • seavey99
    seavey99 Posts: 3
    edited January 2002
    No the 250 doesn't have an LFE. I did hookup my sub with monster sub cable and their directions recomended i just hook to the left input. I guess my question is would i have better sound from the sub if i was hook to both left and right inputs.
  • Firerider58
    edited January 2002
    Sorry,,,,my goof! I was thinking of the 350. Why not go with using the speaker level inputs/outputs? Did you get a manual with your sub? Shows you how to do it. If you don't have one, you should be able to download a copy at the Polk Audio home page. Sorry I gave you the wrong info,,had my 350 on the brain:D
    Ron
  • Firerider58
    edited January 2002
    The info you should need is on page 7. I'm honestly not sure about using Y-adapters and such, and the manual is not really clear about units without an LFE input. You should be safe using the method mentioned.
    Ron
  • lax01
    lax01 Posts: 496
    edited January 2002
    Hey Firerider, I know I have a post out there on this sub, but at the store they did have Y-adapter hooked into the connectors. Just though you would like to know. Try it both ways.
  • Firerider58
    edited January 2002
    Curious as to how this works,,,so what is done then is to run a single cable from the sub-out and then Y-off into the right and left line level inputs?? I have to admit,,,this manual is'nt clear at all on the best way to hook up the lower powered subs.
    Ron
  • cimmy
    cimmy Posts: 7
    edited January 2002
    I hooked up my sub first with the just the left and then tried a y adaptor and nothing changed at all.
    Shhhh.... Don't let My wife know. She thinks that I am buying flowers.
  • seavey99
    seavey99 Posts: 3
    edited January 2002
    Yeah i'm going to just use the left input only as i'm happy with the sound. My reciever only sending a mono signal to the sub anyway so it shouldn't make a difference! :rolleyes: Hey thanks guys for the info.
