Worth restating.
Found this in a 1984 advert for Harmon Kardon:
    VR3 Posts: 29,748
    100%, been saying it for years, it's all about the current.
  • motorstereo
    motorstereo Posts: 2,427
    So.........I'm wondering how much current is considered adequate and is it all created equally? Is tube current the same as ss current?
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,384
    edited May 2022
    "I'm wondering how much current is considered adequate "
    An example might help. Current (amperes) is equal to the square root of the power (watts) divided by the impedance (ohms). So, if we look at producing 350 watts into an 8 ohm speaker that would be the square root of 350/8 which would be 6.6 amperes times 2 (for stereo) which would be 13.2 amperes. This would be for an RMS measurement the peak requirement would be 18.7 amperes (Peak Current = RMS Current x 1.414). So with a power of 350 watts into an 8 ohm impedance the peak stereo demand would be 19 or 20 amperes.
    mhardy6647 Posts: 35,562
    edited May 2022
    That's the thing about discussions concerning Amperes -- they're always current. B)
    If loudspeaker designers hadn't all gone sadistic back ca. the late 1970s and given us loudspeakers with ridiculously low impedance dips and outrageous phase angles -- current would be less of a thing to worry about.
    now, if you'll excuse me, those darned hooligan kids are out on my lawn -- again! ;)
  • SeleniumFalcon
    Tony M Posts: 12,015
    I'm glad I put 14 gauge wire and 20 amp rated outlets in my cottage. :p
  • michaeljhsda2
    michaeljhsda2 Posts: 2,216
    Tony M wrote: »
    :s
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Unknown
    VR3 Posts: 29,748
    Anything less than 200 Amps is not enough😅
  • motorstereo
    VR3 wrote: »
    "how much current does a mcintosh mc1201 have?"
    200 Amperes
    McIntosh MC1201 Amplifiers DESCRIPTION 1200 Watt Mono Power Amplifier Double Balanced, Push/Pull Design Full Power into 2, 4, or 8 ohms 200 Amperes of Output Current
    Wow I cut it pretty close there.
    edited May 2022
    Tony M wrote: »
    So now your wire is the fuse....should you plug a 20amp something into it.
    Maybe I used 12 gauge. ;)
    I'll get back to you guys sometime in the future.
    heiney9 Posts: 25,705
    .......and the 1st watt is the most important
    heiney9 wrote: »
    ... or the first 100 milliwatts for those of us with 104-ish dB/watt @ 1 meter loudspeakers. ;)
    F1nut Posts: 52,406
    You can't use 20 amp outlets with 14 gauge wire. It has to be a minimum of 12 gauge, 10 gauge is even better.
    Viking64 Posts: 7,812
    edited May 2022
    Yeah, 14-gauge wire is for lighting circuits. It's only real value is being able to have an acceptable number of conductors in a switch box to follow code.
    Receptacles should have 20-amp breakers and 12-gauge wire. For a dedicated power amp circuit, I would recommend 30-amp breakers and 10-gauge wire.
    F1nut Posts: 52,406
    I absolutely agree, but be aware that will not pass code, so have a 20 amp breaker stored away for the day you sell your house.
  • BlueFox
    BlueFox Posts: 15,250
    I have three 20 amp lines with 10 gauge wires. Two of the lines are for the amps (one line for each amp), and the third is for the other gear. Before I put each amp on its own line I kept popping the breaker on the circuit for the amps. After adding another line so that each amp had its own line I no longer popped any breakers. However, I did break both speakers one night, but the amps kept on working.
  • maxward
    maxward Posts: 1,742
    What was the cost of the fix for the Magicos?
  • BlueFox
    I have forgotten the cost of the drivers. Probably a few hundred dollars for each one.
