Exterior trim paint recommendations?
daddyjt
I installed a new french-door into my daylight basement 3 years ago. It came pre-primed, and I applied Rustoleum oil based gloss paint on the trim, and in that time, it’s completely flaking off.
Any recommendations for a long-lasting exterior trim paint?
― Aleksandr Solzhenitsyn
Benjamin exterior, but all will peel if not dry and re-primed2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Emerald urethane shirwin Williams
The Rustoleum isn't your problem as the primer is what's peeling right down to the bare wood. If you have moisture problems that should be fixed first. If not I like using a quality oil based primer (if you're lucky enough to find oil based) and top it with an excellent quality gloss latex like Behr Marquee.
Something is very weird there. What is the substrate? Is it wood or a composite wood product? Seems like manufacturing defect.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Gardenstater wrote: »Something is very weird there. What is the substrate? Is it wood or a composite wood product? Seems like manufacturing defect.
It is primed (at the factory) pine…“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
motorstereo wrote: »The Rustoleum isn't your problem as the primer is what's peeling right down to the bare wood. If you have moisture problems that should be fixed first. If not I like using a quality oil based primer (if you're lucky enough to find oil based) and top it with an excellent quality gloss latex like Behr Marquee.
There is no moisture, beyond what the weather sends down (which isn’t much in UT). I can still get oil-based primer here.“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
Was it pressure treated pine? I had a failure like that when painting a pressure treated pine playset for someone once. Not enough time had elapsed and pressure treated pine is inherently moisture laden unless it is kiln dried and kept away from moisture.
Even if it isn't pressure treated it may have had too high of a moisture/sap content when they primed it.George / NJ
iFi nano iDSD DAC
iPurifier3
Agreed. That's not a paint problem. That's a substrate issue. You can clearly tell that the substrate is delaminating and not the paint (as evidenced by the color being peeled up behind the paint)
Is this South facing? Dark colors will cause higher than normal temperature swings causing the wood to expand and contract excessively. Oil based paint, albeit durable, won't flex like a good exterior latex.Gustard X26 Pro DAC
Not really - it gets afternoon sun in the winter, but not after about May 1st.
Sounds like a good stripping and then an oil primer are in order.“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
My first thoughts were, the primer should be a good oil-based alkyd and the finish top coat should be latex.
Good luck, should hopefully be an easy fix.
As a "once-upon-a-time" house painter, I'd prime with a high quality acrylic/urethane bonding primer as it stretches and will not crack with extreme changes in humidity and temperature (Benjamin Moore Stix for example) and then apply two coats of premium house paint like Benjamin Moore Aura. If you have any sun-grayed wood be sure to sand it away as coatings will adhere poorly to such a surface. No connection with BM paint, I just like their products.
Another vote for Benjamin Moore.Political Correctness'.........defined
President of Club Polk -
Benjamin Moore is our go-to as well, FWIW, since the late 1980s when we lived in California.
can't get a real beer, but you can still get oil-based primer in Utah dangnabbit!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I had extensive exterior wood trim professionally painted last fall with Benjamin Moore paint. It takes a beating from sun, freeze-thaw, wind, rain, ice, snow. Looks great! Usually lasts for several years before it starts peeling again. The paint doesn't matter if the surface isn't prepped right though (sanded, filled, and primed) and the paint isn't put on right. Can't be too hot, can't be too cold, can't be too humid.
