Lumin u1 mini versus lumin u1
VR3
So I have had the lumin u1 for a few months now.
The lumin u1 is a far superior transport to the mini. The high end, staging, across the board is a better product.
The lumin u1 mini with the s booster power supply sounds exactly the same as the u1.
End review.
Thanks for reading
End review.
Thanks for reading
A+++++ SOLID REVIEW, VERY CONCISE, FAST READ, HONEST REVIEWER, WOULD READ AGAIN!
Need pictures of the speakers Lumin U1Came. Back to see pics... Sadly disappointed2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Only pics I have on hand. The u1 is a masterpiece as far as the chassis goes.
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks Drew!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey, have you had your ears on a 851N? If so what do you think the delta to the mini is? At some point on the future, I am thinking about moving on from the 851N and trying to stay in the 2-3k price point if it makes sense to. A local group (and a dealer within) I am part of swear by the Matrix X Sabre 3 streamer/DAC but I am an exploring all the options2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
The mini has no DAC, but I do recommend it as a dedicated streamer!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I will def be staying with an external DAC, the NSD for now and maybe something else in the future2 Channel in my home attic/bar/man cave
Lumin sets up in ten minutes or less, sounds impeccable and is compatible with most anything.
The mini definitely needs the s booster for the best sound- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The Lumin X1 power supply offers:
Solid billet construction using all the same techniques as your main chassis
Thick aluminium walls provide even more shielding
Available in anodised black and raw silver
Supplied with a custom cable for S1 / A1 / T1 / U1 compatibility
Separate digital and analogue circuitry
Low-noise Linear Regulator
The highest quality components used throughout
Price $2500
It better best the sBooster!
https://www.luminmusic.com/lumin-x1-psu.htmlAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
When I upgraded my Lumin S1 with the X1 power supply the sonic improvement was immediately apparent. Later when I bought an X1 it's improvement over the S1 was again immediately apparent. Now I'm looking forward to whatever replaces the X1 sometime in the future.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I could be wrong, but I don't see how the x1 power supply would benefit the u1. The main selling point is independent supplies for the analog and digital circuits... The u1 has no analog circuits.
Either way I'm not paying that much for a power supply. Maybe if one showed up used for 350 to 500, maybe- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Lemme know when you are ready to sell your X1, I'll drive down and pick it up!
Edit: As long as it doesn't smell like cat
