SDA-2A, Has anyone tried to remove the toe-kick/ courtesy panel?
I pulled two wood screws located on the inside of the cabinet.
Appears to be attached with adhesive also...
Tried driving a putty knife into the seam...
Very little movement...
Anyone get this piece off without a bunch of damage?
I want to apply new laminate to the cabinets, and am pleased to replace that piece.
Answers
    xschop Posts: 5,665
    Never understood why that janky appendage.
    F1nut Posts: 52,165
    Never tried to remove that piece. No doubt it is glued on.
  • Baker
    Baker Posts: 18
    Two ideas:
    Table saw with speaker cabinet vertical. I will not be able to achieve full depth, but will decrease the amount of surface area by half. The saw kerf will make a larger area to work within. Maybe a wedge to pop the adhesive?
    Radial arm saw with a dado blade. Set the depth to be slightly above the cabinet. Turn the part into sawdust... Yes, height may be an issue. May be necessary to turn the saw column 180 degrees, and work on a second bench.
    xschop Posts: 5,665
    Claw hammer, follow up with wood putty.
  • Astrl55
    Astrl55 Posts: 68
    edited April 2022
    IF -- IF, I was determined to remove that piece, I would employ a router sled* before I would take my life in my hands with the combination of a dado setup on a radial arm saw.
    I speak from experience in two areas of my previous life -- woodworker & attorney.
    *measure 3 times; router once
  • Gardenstater
    Gardenstater Posts: 4,858
    edited April 2022
    Yes. Router and a straightedge clamped to the cabinet. I'd make the straightedge out of some material the same thickness as the toe plate with an added fence of material secured to that. Run the router on your straightedge to make the first cut in the straightedge base. Make one pass at a time and keep moving the straightedge down until you get the whole panel. I think the size of cabinet is too large to use a router table or a table saw w/ dado blade but that could work too with the proper supports and a long enough fence.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    Toolfan66 Posts: 18,292
    There could be wooden dowel pins that were used as well when put together..
  • Baker
    Baker Posts: 18
    Yes, Router will be the best tool for the job.
    I’ll see about doing the first one this afternoon.
    And indeed, I’ll watch for dowels.
    That was very helpful advice, thank you.
  • Baker
    Baker Posts: 18
    Like a fat man into the bathtub...
    Nice and easy...
    The piece fell away at the last 1”.
    Secret of the toe-kick was to hide sin at the bottom gap? Larger than all the others...
  • Baker
    Baker Posts: 18
    edited April 2022
  • Gardenstater
    edited April 2022
    Nice to have the facilities of a machine shop* when making jigs etc.. You really did that up!
    * and tool and die maker skills ;)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,665
    Will you extend the grill cover and update the look?
  • Baker
    Baker Posts: 18
    No, that piece will be replaced with hard maple to match the Formica that’s going on.
    Yes, machine shops are magical places...
    F1nut Posts: 52,165
    Formica!?! Use wood veneer instead.
    xschop Posts: 5,665
    Formica is cold beverage friendly.
    F1nut Posts: 52,165
    xschop wrote: »
    But it will present a hard edge.
    pitdogg2 Posts: 27,577
    Mah...he'll just be locked into hard rock then....
    xschop Posts: 5,665
    Some cold beverages present a hard edge. I vote black Formica.
