Phono pre recommendation....
tonyb
More specifically, a good sounding cheap phono pre...lol. Picked up a cheap Pioneer PL-450, near minty with a good AT90 cart on it looks like. Basic table, easy to operate for the wife. Anyway, cheaper the better but I know....ya get what ya pay for. Probably run it through the line level input on the Grant Fidelity tube dac after the phono pre. Something sound decent for not alot of coin out there?
Used works well too, if any of ya got something in the closet ya want to sell.
I have an audio alchemy vac-in-a box that I bought here years ago. You can have it for free if you like.
I have a Parasound Z-phono I'm willing to part with. Too much gain when combined with my Belles pre which also has a lot of gain. PM me if you're interested.Gustard X26 Pro DAC
Got a decent sound to it Bob ?HT SYSTEM-
lsi 9's -
dude. it's free. The value proposition is infinite -- as long as it works.
Serious PS/edit/aside: I'll vouch for the generosity of @WagnerRC, if that adds any value.
It looks like quite the package.
https://www.vinylengine.com/library/audio-alchemy/vac-the-box.shtml
I’ve had good luck with Cambridge products….I plan for the future. - F1Nut
^^^Was gonna mention TroyD has a 640P for $90!^^^
I’ve been going all digital, otherwise, I’d be all over that.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Hey Tony. I bought a z- phono for my wife’s setup. Been a great addition and sounds pretty good for the price.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
Thanks gents, let me see if I can snag that z-phono..HT SYSTEM-
lsi 9's -
The CIAUDIO that Drew has in the FM seems like a great deal. I strongly considered it, but ultimately decided it was more than I wanted to invest in my modest, seldom used vinyl setup. I ended up getting a Vincent PHO-300. My initial impressions are positive, but I’ve only listened to one album. All a moot point I suppose since it looks like you’ve decided on the z-phono, but I thought I’d go ahead and share anyway.Things work out best for those who make the best of the way things work out.-John Wooden
It is on its way.Gustard X26 Pro DAC
So is the coin bro, thanks again.HT SYSTEM-
lsi 9's -
I have one of the Parasound phono preamps that predated the Zphono that I picked up for $100. I was surprised what a dedicated phono pre can do vs the built-in, even on compared to my Marantz integrated amp.Stan
Main 2ch:
HT:
Other stuff:
