Musical Fidelity Phonostages - WAV file samples
jdjohn
jdjohn Posts: 3,459
This is not very scientific, but I've recorded the same track - Dire Straits, Love Over Gold - with two different Musical Fidelity phonostages. One is the MF Nu-Vista Vinyl, which retails for ~$3,000USD, and second is the MF MX-VNYL, which sells new for ~$800USD.
Here is a link to the MF Nu-Vista WAV file: https://drive.google.com/file/d/1daVWNDE6BcHMN6U20wiJOEBD2TDdmwve/view
And this is the MX-VNYL sample:
https://drive.google.com/file/d/1zGBo6uJa1Li7XaRJQfpc0aDP4JdMITB7/view
I'm not trying to drive direction one way or the other, but perhaps exhibit the difference in sound, and relate it to the difference in price.
I would recommend using headphones for discerning differences in sound between these two files.
P.S. Turntable, tonearm, and cartridge were as follows:
Logic DM-101 turntable
Micro Seiki MA-505 tonearm (and corresponding MS headshell)
Grace F9 MM cartridge (with SoundSmith RS-9U line-contact replacement stylus)
    mhardy6647 Posts: 35,562
    Access: requested.
  • Gardenstater
    Gardenstater Posts: 4,991
    Access requested :)
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • jdjohn
    jdjohn Posts: 3,459
    that appears to have worked :)
    Not to go all ASR on this ;) but it might have been fun and interesting for you to have "blinded" the two links and let folks experience the two samples (blissfully) unaware of which was which.
  • TroyD
    TroyD Posts: 13,124
    Heresy, Doc.
    Heresy
  • jdjohn
    jdjohn Posts: 3,459
    I thought about doing that @mhardy6647 , but decided against it since it is only two files. However, I noticed that the original MX-VNYL file had about 0.5db more gain, so I bumped the Nu-Vista up to match it. Also, I clipped a little time off the ends so that the files are the same length.
    Anyway, here are new files for both:
    MX-VNYL(2) https://drive.google.com/file/d/1T4qnhUSB4zxbpIS-AXbgxFxKM4n-3vut/view?usp=sharing
    Nu-Vista(2) https://drive.google.com/file/d/1sYEFhKkIukyNL3chLCDeFcbL-BlK2w4w/view?usp=sharing
    VR3 Posts: 29,762
    Using my phone speaker, the nu Vista sounds better
  • jdjohn
    jdjohn Posts: 3,459
    Well, just cuz...here is another sample file through an 'Italian-job" Royal Device Rubina JFET MM-only phonostage: https://drive.google.com/file/d/1fJYXgVjwTKF_XIo36mxq8i89jvqF7rec/view?usp=sharing
    Interested to see if anyone has a strong opinion about this result.
