Monitor 10 s have very low woofer volume
Is a capacitor to blame for low woofer volume?
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,322
    Usually the problem is related to either one or both of the 6.5" active drivers not working. The possible exception would be of someone has recently replaced one or both of the drivers and not maintained the correct connection polarity.
    Tony M Posts: 11,801
    Or wired the rear posts backward on one speaker.
    I did that once and the speakers had minimal bass output.
    pitdogg2 Posts: 27,447
    Do the cones move freely with no scratching ? Do not force them if not.
  • Jimbo18
    Jimbo18 Posts: 2,351
    Leaky cabinet?
  • atprn
    atprn Posts: 4
    Speaker has never been worked on. The volume is barely audible. The tweeter appears to be fine.
  • boston1450
    boston1450 Posts: 7,758
    atprn ^^^^^ did you do this ?
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    Use 2 fingers at 9oclock & 3oclock & lightly push in on woofers (push in on woofers near dust cap dome area)....... Another way you can also push out on Passive Radiator & the woofers should come out with ease
    Randy-Maine
    by David WMG
  • boston1450
    Also you can test your cabinets to see if they are air tight. Push in (lightly) & HOLD IN the passive radiator & woofers will come out & they should stay out for 3-5 seconds
    Randy-Maine
    by David WMG
  • TennMan
    TennMan Posts: 1,266
    atprn wrote: »
    Sounds like there might be a problem powering the speakers to me. Have you tried a different amplifier, preamp, etc.?
  • atprn
    atprn Posts: 4
    Tried swapping r and left speaker wires and same issues apply to only to the same speaker. Could a crossover capacitor be the issue?
  • Gardenstater
    Gardenstater Posts: 4,811
    What about ruling out the other things that people have suggested so far^^ ?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • TennMan
    atprn wrote: »
    You seem to be hung up on capacitors. If you really want to know the answer to that question, swap the crossovers between speakers. It's an easy job. If the problem goes with the crossover, upgrade the crossovers with new caps and resistors.
  • Hansvelton
    Hansvelton Posts: 151
    edited March 2022
    TennMan wrote: »
    atprn wrote: »
    A crossover cap *bad) in the woofer circuit usually would not make the volume very low.
    As the low pass cap in these, simply divert some of the upper range of the woofer around it.
    If anything it would allow more of the upper range INTO the woofer, and make it just worse sounding overall.
    Now a loose connection to the big inductor, WOULD create issues, but I think that would be obvious.
    I think pulling the woofers, but first checking for voice coil rub is in order, if they pass THAT test, then direct wire a signal to Each midwoofer and see if they work, effectively bypassing the crossover.
