Looking for a pair of monitor 10 c ? grills
Looking for a pair of monitor 10 c ? grills see pictures of speaker that they are needed for, polk monitor 10 I believe they are 10C not 100%, if any one has a set they are willing to sale please let me know, Thanksewe80zp2kcja.jpg
    Tony M Posts: 11,753
    edited March 2022
    Hi.
    I've bought some smaller Polk audio speaker grills off of eBay a couple of times. I also bought a center channel grill off of eBay for a friend.
    I had a saved search engaged so after searching and not finding one, they emailed me when one was posted.
    Good luck to you.
    I just looked and didn't see grills for you.
    How about a friend with some woodworking tools or a local woodworking shop?
    They can make a frame. The peg "pockets " can be bought from Parts Express for cheap.
    I've re-clothed a bunch of grills and it not that hard at all. Staplers aren't too costly.
    Again, good luck.
  • Gardenstater
    Gardenstater Posts: 4,804
    If you make your own be sure to use MDF instead of Particle Board. It is denser and has a higher Modulus Of Rupture (Bend Strength) and Modulus of Elasticity (stiffer)
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
